Power Transmission, Gear, Pulley
The discussion centers on lifting a 75-pound load using only 4 pounds of force, with a focus on gear and pulley systems. Participants recommend exploring block and tackle designs, acknowledging that friction may necessitate a complex setup with over 20 parts. Additionally, an electric winch and hydraulic systems are suggested as alternatives. A unique idea involving a Tesla turbine for torque conversion in electric bicycles is also presented, although its feasibility is questioned.
  • Understanding of block and tackle mechanics
  • Familiarity with friction and its impact on mechanical systems
  • Knowledge of electric winches and hydraulic lifting systems
  • Basic principles of torque and gear reduction
  • Research block and tackle design principles
  • Investigate electric winch specifications and applications
  • Explore hydraulic systems for lifting and their efficiency
  • Study Tesla turbine mechanics and potential applications in torque conversion
Engineers, hobbyists building electric bicycles, and anyone interested in mechanical lifting solutions and torque conversion technologies.
redsox1701
I need to lift 75 pounds when only using 4 pounds of force. Is there a gear set or pulley system that can do that?
Thanks
Research the block and tackle.
Lots of ways to do that. The question is which means works best for this application. But then you have not told us anything about this application except the input and the output.
The idea to look into block and tackle design is a good one, and the most obvious. But by the time you figure in friction you are probably looking at 20 parts of line or more. That many parts creates other problems that might drive you to a different lifting method. This is the point where more details would be useful.
electric winch with a 3lb button :approve:
Simplest of all, a lever.
Hydraulics!
Hi I am building an electric bicycle and I want to use a high rpm(6-8000 rpm) brushless motor. the gear reducers I've found have not been able to hande more than about 4000rpm. I was wondering if anyone has heard of using a tesla turbine as a sort of reduction/torque convertor. My idea is to make something that looks like a clutch with input and output disks stacked and sandwiched with low tolerance in some sort of viscous oil and use the surface cohesion to transfer torque. In my mind the molecules of oil would roll against each other and create a kind of planetary like reduction. Is that completely ridiculous?
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 33 ·
