How Do You Solve a Pre Calculus Problem with Congruent Sides and Diagonals?
To solve the pre-calculus problem involving a quadrilateral with congruent sides and a diagonal of length 6, the goal is to find the value of x such that the area of the shaded region is 40% of the area of the unshaded region. The equation derived is x/(6-x) = 0.4, leading to the solution x = 1.71. The areas of the shaded and unshaded regions are represented as S1 and S2, respectively, and the relationship S1/S2 = 0.4 is key to solving the problem. The calculations confirm that the approach is correct, emphasizing the importance of understanding how the areas are derived. The final answer is x = 1.71.
shawonna23
[SOLVED] Pre Calculus Homework Problem...Help!
1. Homework Statement
A quadrilateral has two pairs of congruent sides and a longer diagonal of length of 6, as shown. For what value of x will the area of the shaded region be 40% of the area of the unshaded region?
2. Homework Equations
x=.40(6-x)
3. The Attempt at a Solution
x=1.71
the area of shaded region is S1 = x*a and of unshaded S2 = (6-x)a. You also know that S1/S2 = 0.4 . Now just solve the equation for x.
Pre Cal Hwk Problem: Answer
x(a)/(6-x)(a)= 0.4
The a's cancel out...so that leaves me with: x/(6-x)=0.4 x=2.4/1.4 x=1.71
Is my work correct?
It looks fine. The important thing is to realize where the areas came from.
Thanks for the help!
13K
  • · Replies 24 ·
