Precalc project: positive values in an inequality
The discussion focuses on solving the inequality (1/x) - (1/(x-1)) > (1/(x-2)) to determine the set of positive values of x. Participants suggest that the problem is a multiple-choice question with five options for intervals. The recommended approach includes combining fractions, analyzing the behavior of the inequality across different intervals, and substituting values from the options to verify which intervals satisfy the inequality. The conclusion emphasizes that substitution can be a quick method to identify the correct answer without fully solving the inequality.
  • Understanding of inequalities and rational expressions
  • Basic knowledge of interval notation and union of sets
  • Familiarity with the concept of positive and negative intervals
  • Ability to perform algebraic manipulations with fractions
  • Learn how to combine rational expressions in inequalities
  • Study interval notation and how to express solutions using unions
  • Explore methods for testing intervals in inequalities
  • Practice solving similar inequalities involving rational functions
Students in precalculus, educators teaching inequalities, and anyone looking to improve their skills in solving rational inequalities and understanding interval notation.
hpdwnsn95
Determine the set of positive values of x that satisfy the following inequality:
a) (0, 1) union (2^1/2, 2) b) (0, 1/2) union (1, 2) c) (1/2, 1) union (2^1/2, 2(2^1/2))
d) (0, 2^1/2) union (3/2, 2) e) (1, 2^1/2) union (2, 2(2^1/2))
i'm not sure that there are any relevant equations, just started precalc a few weeks ago and I'm not sure how to solve the problem
I've tried graphing the equation and then tracing x to find y, but I haven't been able to find an answer that way. I've also tried solving for x which i get 1/2 > x for, but I'm not sure if that applies to this problem
The first step would be to combine the two fractions on the left side.
Is this actually a multiple choice question? Is that what the a) b) c) etc refer to ?
Remember that if this is a multiple choice question, you do not have to find the answer, you only have to identify which of the 5 offerings is the answer.
While not a great method of solving a problem, substituting the offerings into the original inequality may be the fastest way for you to solve this.
If you do not know or see a clever trick to use, then solving the problem using basic principles is the best way. In the sample problem, start by adding the additive inverse of the righthand member to both sides; then perform the arithmetic steps for the rational expressions. You have some rational expression related to zero. Now just focus on the numerator.
Given that x is positive, I would separate this problem into three parts:
x between 0 and 1: both x- 1 and x- 2 are negative.
x between 1 and 2: x- 1 is positive but x- 2 is negative
x greater than 2: both x- 1 and x- 2 are positive.
For each of those, multiply the entire inequality by x(x-1)(x-2).
yes it is
I would do that but I don't understand the answer format, i"ve never seen union answers before, can you (or anyone else) expain them?
Do you know what the definition of the union of two sets is?
i think union stands for and right? so it's like one set & one set
but I'm not sure how would plug either set into the problem because there's no y in the problem
One piece (interval) of the x-axis plus (as in union) another piece. --- Actually, all the numbers in one interval together with all the numbers in another interval together with ...
The first option
suggests it is true for any value between 0 and 1, as well as values between √2 and 2, but false for values between 1 and √2, and false for values above 2
it is clearly undefined for x = 0,1 or2 due to a fraction becoming 1/0
You could substitute 0.5 [1/2], and check it is true, 1.25 [5/4] and check it is false, 1.5 [3/2] and check it is true and 3 to check it is false.
Solving is better, but substitution could be your last resort.
