MHB Predict Z-Score for Y Given X at 30th Percentile
  • Thread starter Thread starter dlee
The discussion focuses on predicting the z-score for variable Y given that variable X is at the 30th percentile, with a specified correlation of ρ = 0.7. The initial calculation suggests a z-score of -0.524 for Y based on the assumption of a bivariate normal distribution. However, the correct z-score is -0.364, which is debated among participants. The conversation emphasizes the importance of correctly modeling the correlation and the relationship between the z-scores of X and Y, ultimately concluding that the standardized nature of the variables simplifies the calculation. The relationship between the z-scores is confirmed through simulation, reinforcing the derived correlation.
dlee
Consider two random variables X,Y whose correlation is ρ = 0.7 (and the joint PMF is football shaped). Predict the z-score for Y if you observe that X is at the 30th percentile (assuming X ~ N(4,4)).
The solution to this problem is -0.364, but I'm not sure how to approach this answer.
Re: Correlation?
I we assume a bivariate normal distribution, we "expect" the relation:
$$y(x) = \text{sgn}(\rho) \frac {\sigma_Y}{\sigma_X} (x - \mu_X) + \mu_Y$$
With X at the 30th percentile, that means $z_X = \frac{x - \mu_X}{\sigma_X} = \text{invNorm}(0.30) = -0.524$.
In other words, the z-score for Y is
$$z_Y = \frac{y - \mu_Y}{\sigma_Y} = \text{sgn}(\rho) z_X = -0.524$$
I don't know how they got to -0.364.
Re: Correlation?
That can't be right.
You can without loss of generality assume $$\mu_X = \mu_Y = 0$$, so we have a model:
$$y=\alpha x$$
then $\displaystyle \sigma_Y=\alpha\; \sigma_X$, and $\rho=E(XY)/(\sigma_X \sigma_Y)=\alpha\; \sigma_X/\sigma_Y$
Hence: $$\alpha=\rho \frac{\sigma_Y}{\sigma_X}$$...
Re: Correlation?
I didn't.
The problem asks for a z-score, meaning $\mu_X$, and $\mu_Y$ get eliminated (see my derivation).
so we have a model:
$$y=\alpha x$$
Well... multiplying by 0.7 almost gives the requested result.
But that won't be right.
Re: Correlation?
I like Serena said:
... Well... multiplying by 0.7 almost gives the requested result.
It will be if you use "nearest value" in inverse normal lookup in a table.
Re: Correlation?
I like Serena said:
I didn't.
Well, since you failed to set up a model with the correct correlation it is not irrelevant to make an observation that simplifies setting the correlation without changing the answer.
Re: Correlation?
The model is a positive sloped football that could be anywhere.
The problem puts the heart at x=4 with a variance of 4.
The y coordinate of the heart and the slope can still be freely chosen.
Then, with the given correlation, the "width" of the football becomes fixed.
Either way, when talking about the z-score of y, all these choices become moot, since they are standardized.
The relationship between $E(z_Y|z_X)$ and $z_X$ is simply $E(z_Y|z_X) = z_X$, whichever model you pick.
This is a "standardized" football that is aligned on the line y=x with a width such that the correlation is satisfied.
Re: Correlation?
The y coordinate of the heart and the slope or can still be freely chosen.
Then, with the given correlation the "width" of the football becomes fixed.
Since for Bivariate normal rv $X,\ Y$:
$$E(Y|X)=\rho\; \frac{\sigma_Y}{\sigma_X}Y$$
So as $z_X,\ z_Y$ have the same correlation coefficient as $X$ and $Y$ we have:
$$E(z_Y|z_X) = \rho\; z_X$$
See: http://athenasc.com/Bivariate-Normal.pdf.
... And simulation confirms this.
11K
