Pressure gradient along a streamline using CV analysis
4 replies · 2K views
Bohr1227
Use a CV analysis to show that an element of fluid along a streamline gives
\[\partial p/\partial x=-\rho u\partial u/\partial x\]
\[\sum F=\oint_{CS}^{ } \rho \overrightarrow{V}(\overrightarrow{V_{rel}}\cdot \overrightarrow{n})\]
Using a CS with following conditions on left side: u and p.
Following conditions on right side of the element: \[u+\partial u/\partial x\Delta x] and \[p+\partial p/\partial x\Delta x]
Just looking at it per unit width inside the paper: (Neglecting small factors)
\[(p-(p+\partial p/\partial x\Delta x))\Delta y=\rho ((u+\frac{\partial u}{\partial x}\Delta x)^{2}-u^{2})\Delta y=\rho (u^{2}-u^{2}+2u\frac{\partial u}{\partial x}\Delta x))\Delta y\]
This gives:
\[\frac{\partial p}{\partial x}=-2\rho u\frac{\partial u}{\partial x}\]
I get the answer with a factor 2, which I am not supposed to get. What do I do wrong?
This gives:
Did you review this before you posted it to make sure that the LaTex displayed properly?
Sorry about the first post, I didn't review the latex, and apparently it is not possible to edit it...so here is the edited version:
1. Homework Statement
[tex]\frac{\partial p}{\partial x}=-\rho u\frac{\partial u}{\partial x}[/tex]
[tex]\sum F=\oint_{CS}^{ } \rho \overrightarrow{V}(\overrightarrow{V_{rel}}\cdot \overrightarrow{n})[/tex]
Following conditions on right side of the element: [tex]u+\frac{\partial u}{\partial x}\Delta x[/tex] and [tex]p+\frac{\partial p}{\partial x}\Delta x[/tex]
Just looking at it per unit width inside the paper: (Neglecting small factors because [tex]\Delta x\rightarrow 0[/tex])
[tex](p-(p+\partial p/\partial x\Delta x))\Delta y=\rho ((u+\frac{\partial u}{\partial x}\Delta x)^{2}-u^{2})\Delta y=\rho (u^{2}-u^{2}+2u\frac{\partial u}{\partial x}\Delta x))\Delta y[/tex]
This gives:
[tex]\frac{\partial p}{\partial x}=-2\rho u\frac{\partial u}{\partial x}[/tex]I get the answer with a factor 2, which I am not supposed to get. What do I do wrong?
You are right, I did not review it. I'm sorry, but it is fixed now.
Thank you!
This gives:
I don't see how you get the right hand side of this equation:
