Calculating Pressure Change in Liquid After Adding Weight
  • Context: Undergrad
  • Thread starter Thread starter mr.book
    Liquid Pressure
The discussion centers on calculating the pressure change in a liquid after an object, specifically an aluminum ball, is introduced into a cup of water. The key equation referenced is p = ρgh, where ρ represents the density of the liquid, g is the acceleration due to gravity, and h is the height of the liquid column. When the ball is added, the water level rises, resulting in an increase in pressure at the bottom of the cup due to the increased height of the water column. The initial conclusion is confirmed that the pressure at the bottom increases as the depth of the water increases.
  • Understanding of fluid mechanics principles
  • Familiarity with the equation for liquid pressure (p = ρgh)
  • Basic knowledge of density and its role in pressure calculations
  • Concept of hydrostatic pressure
  • Research the effects of buoyancy on submerged objects
  • Explore the relationship between liquid density and pressure in different fluids
  • Learn about hydrostatic pressure in varying depths of liquids
  • Investigate real-world applications of fluid pressure calculations in engineering
Students studying physics, engineers working with fluid dynamics, and anyone interested in understanding the principles of pressure in liquids.
mr.book
This started to bother me today. In the first picture, there's a cup wheres a certain amount of water in it. A ball made of aluminium hasnt been dropped in the cup yet.
In the second picture, the ball has been dropped in.
The ball has not sinked, a string is holding it.
Now please tell me, how did the pressure on the botton of the cup created BY THE WATER change?
I mean, the water level just rose. So the pressure should also.
But there seems to be another solution to the problem, and I just can't figure it out.
The equation for liquid pressure is p= RO*g*h.
Thanks in advance,
______________________________________
[PLAIN]http://www.cornerpocketpool.com/images/catalog/category57.jpg
http://www.billiardlover.com/mcdermott-pool-cue.html
Your initial solution is correct. Since the depth of the water is now larger, the pressure at the bottom is higher.
15K
10K
