Pressure of an electron gas at 0K
The pressure exerted by a Fermi electron gas at 0K, known as electron degeneracy pressure, is quantitatively related to electron concentration. The derivation involves calculating the energy of electrons using a quantum mechanical "particle in a box" model, where the pressure is determined by taking the derivative of energy with respect to volume. The approximate pressure is found to be 2/3 of the density times the Fermi energy, while a more exact approach yields 2/5 of the density times the Fermi energy. This indicates a significant reduction in ground state energy when electrons are allowed to occupy higher energy states rather than being confined to lower states.
  • Understanding of Pauli's exclusion principle
  • Familiarity with quantum mechanics, specifically the "particle in a box" model
  • Knowledge of Fermi energy and electron concentration
  • Basic principles of statistical mechanics
  • Study the derivation of electron degeneracy pressure in detail
  • Learn about the implications of Fermi energy in different physical systems
  • Explore the concept of momentum flux in quantum gases
  • Investigate the role of electron gas in astrophysical contexts, such as white dwarf stars
Physicists, students of quantum mechanics, and researchers interested in statistical mechanics and the behavior of electron gases at absolute zero.
nvs9
What is the pressure exerted by a Fermi electron gas at 0K? I know that from Pauli's exclusion principle there must be a non zero pressure even at 0K, but what is the quantitative relation between this pressure and the electron concentration? How do I go about to derive this?
You mean you want to derive the Electron Degeneracy Pressure?
By electron gas at 0K, does one infer the electrons are not moving, and there positive charges to neutralize, or are the electons packed (which doesn't seem like much of a gas)?
I would expect a fair amount of coulomb repulsion on whatever unit cell.
Pressure is also equivalent to energy density.
You are talking about electron degeneracy pressure. What you do is, use the density to determine the volume of the "box" each electron occupies (1/density). Now do a quantum mechanical "particle in a box" calculation to find the energy of that electron. Now take the derivative with respect to volume of the energy-- that's the pressure.
Physically, what is happening here is that even at 0K, the electron wave function has a second derivative so that it can stay inside the box of volume allowed to each electron (to keep them from infringing on the states of the other Fermions). That second derivative (a la Schroedinger) implies the presence of kinetic energy, even at 0K. The presence of kinetic energy means there is momentum flux, and where there's momentum flux, there's pressure.
Thanks Ken G.. I have been able to find the electron gas pressure as a function of the electron concentration using the approach tht u mentioned.
I'm assuming this isn't homework =)
Have a look at my derivation here: http://www.physics.thetangentbundle.net/wiki/Statistical_mechanics/Fermi_gas
and let me know if anything needs clarification.
Yes, this is the exact approach, involving a lengthy yet suitably elegant calculation that even includes arbitrary (half-integer) spins. To be clear, my description above is heuristic, intended to approximate the physics simply and with the right scalings, more so than getting an accurate answer. The approximate way can almost be done in your head if you know the exact particle-in-the-box solution for a 1/density sized box, and you get that the pressure will come out roughly 2/3 of the density times the Fermi energy, whereas lbrits' exact approach comes out 2/5 of the density times the Fermi energy. So I'm about 5/3 high, expressly because my way does not involve ever calculating a Fermi energy. You get what you pay for.
Physically, what this all means is you get about a 40% reduction in the ground state energy if you let all the electrons spread over the whole volume (say the whole white dwarf star), but stack them to higher and higher energies as the lower states fill, rather than just have them all be excited to identical energies in the ground state of their own little boxes. That comparison makes for a cute problem for anyone bored with the standard degeneracy pressure fare!
