Pressure on Piston: Conservation of Energy Explained
This discussion clarifies the concept of pressure in relation to forces acting on a piston in a fluid system. It establishes that pressure is an intensive property, defined as the force per unit area (P = F/S), and cannot be summed across different areas or forces. The confusion arises from misinterpreting pressure as an extensive quantity, leading to incorrect conclusions about conservation of energy. The correct understanding is that the pressure exerted by multiple molecules on a piston does not equate to a summation of pressures but rather reflects a uniform pressure across the surface area.
  • Understanding of basic fluid mechanics principles
  • Familiarity with the concepts of pressure and force
  • Knowledge of intensive vs. extensive properties in physics
  • Basic grasp of hydrostatics and equilibrium conditions
  • Study the principles of hydrostatics and how pressure behaves in fluids
  • Learn about intensive and extensive properties in thermodynamics
  • Explore the concept of equilibrium in fluid systems and its implications
  • Investigate the relationship between force, area, and pressure in various applications
Students of physics, engineers working with fluid dynamics, and anyone interested in understanding the principles of pressure and force in mechanical systems.
CGandC
Suppose there is a tank filled with water and a piston of area S exerts a force F on the water.
Suppose I divide the water boundary touching the piston to - N small equal " square " molecules.
Then , the force on the upper face of each molecule is F/N .
Also, the area of the upper face of each molecule is of length S/N .
Thus , the pressure on each molecule touching the piston is : ## P = \frac{F/N}{S/N} = \frac{F}{S} ##
And this is the same pressure that each molecule exerts on the piston
Question: If ## P = \frac{F}{S} ## is also the pressure that each molecule ( touching the piston ) exerts on the piston, then , if I sum the pressures exerted by each such molecule on the piston, I get:
## P = \frac{F}{S} + \frac{F}{S} + ... + \frac{F}{S} = \frac{N*F}{S} ##
which contradicts conservation of energy and also because it just seems wrong because I was told the pressure on the piston is just : ## P = \frac{F}{S} ## and not ## P = \frac{N*F}{S} ##
Why is there contradiction of conservation of energy and why the pressure on the piston is not ## P = \frac{N*F}{S} ##?
Pressure is an intensive quantity, not an extensive one. You sum forces, not pressures.
Well, you can sum pressures if they all act on the same patch of surface, but then we would have pressure NF/S acting on area S/N for a total force of F and an average pressure over S of F/S.
So if for example, I have a trapezoid block of mass and two pistons are acting on either side of it, each exerting force F1 and F2 upon the faces L1 and L2 respectively, as shown in the figure below:
Then, I think the total pressure on the trapezoid should be:
## P = \frac{F_1}{L_1} + \frac{F_2}{L_2} ##
But according to what you said, pressure is an intensive property so summation like this cannot be done.
So my question is: what should be the total pressure acting on the trapezoid?
You seem to have a fundamental misunderstanding of what pressure means. It is not the property of an object as a whole, it is a local property that describes force per unit area over an intersection. In your trapezoid example, the pistons need to apply the same pressure for the system to be in equilibrium - the hydrostatic pressure of the liquid. Otherwise you cannot apply hydrostatics, which is also what let's you assume that the pressure is constant throughout the liquid.
And maybe one regarding compression and tension.
Compression is not a force, exactly, but more a pair of equal and opposite forces. Even just looking at the forces rather than pressure, the compression is not F1+F2. Assuming equilibrium, the compression is F1=F2.
  • · Replies 23 ·
  • · Replies 32 ·
