Best Pressure Sensor for 125°C, 3 bar Environment: Options and Considerations
  • Thread starter Thread starter JT Smith
    Pressure Sensor
The discussion focuses on selecting a pressure sensor suitable for environments with temperatures up to 125°C and pressures between 1 and 3 bar absolute. Participants recommend considering the ProSense series pressure sensors, which can handle these specifications, albeit at a higher cost. The need for a digital interface is noted, though it is not critical, and alternatives such as analog pressure transducers are discussed. The use of a U-tube configuration for sensor placement is suggested for applications where fast dynamic pressure changes are not required.
  • Understanding of pressure sensor specifications, including temperature and pressure ranges.
  • Familiarity with digital and analog pressure transducer interfaces.
  • Knowledge of pressure measurement techniques, including U-tube configurations.
  • Basic concepts of temperature compensation in sensor applications.
  • Research ProSense series pressure sensors for specifications and pricing.
  • Learn about analog pressure transducers and their digital output options.
  • Investigate U-tube configurations for pressure sensor installations.
  • Explore temperature compensation techniques for pressure sensors in high-temperature environments.
Engineers, product designers, and technicians involved in selecting and implementing pressure sensors in high-temperature and high-humidity environments.
JT Smith
I'm trying to find a small pressure sensor for an environment that will be between 1 and 3 bar absolute, 10 to 125°C, and 100% humidity.
By small I mean a port that's no larger than about 1/4" (sorry for mixing unit systems). Ideally I'd like to have a digital interface but it's not critical. And full temperature compensation would be wonderful, but if I have to I can calibrate across temperature and pressure.
What's my best option? I'd love to get away for no more than about $50, but I can probably spend around $150 if I have to. Is this possible?
Thanks in advance.
Is the ambient operating environment temperature reach as high as 125°C or is that the temperature of a fluid or gas being sensed.
Both. The sensor will be mounted on the exterior of a metal vessel which will contain the hot vapor. So the vessel itself will be close to the same temperature. But the environment outside the vessel will be room temperature and normal humidity.
How do you mean? Digital as in on/off (above/below a setpoint) - that is, a pressure switch, or an analog pressure transducer with the output coded into some manner of digital format?
125°C wetted is just barely do-able in an affordable analog pressure sensor. Specs for ProSense series pressure sensors as an example.
I meant a digital interface for reading the sensor would be the simplest but it is by no means a requirement.
Thanks for the link. I was hoping something less expensive might be available but I kind of suspected that would not be the case.
If you are not reading fast dynamic changes of pressure then the actual sensor can be mounted away from the pressure vessel and connected by a suitable shaped tube .
Most commonly a U tube with the outer leg longer than the vessel connection leg is used so that gauge is above the level of the actual port . There are several alternative configurations though .
Common practice . First devised in the early days of steam technology for connecting mechanical pressure gauges to boilers .
That was my first thought, to use a pigtail kind of isolation. But I worry this will perturb the system significantly. It's a fairly small chamber.
What sort of frequency response do you need from your sensor?
The pressure will be relatively slowly varying. A response time of 100ms would be adequate.
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 39 ·
15K
