Pressure-Time relation for polytropic thermodynamic process
The discussion revolves around the theoretical relationship between pressure and time during the sudden release of oxygen from a cylinder, particularly in the context of a polytropic thermodynamic process. Participants explore various theoretical frameworks and equations that could describe this phenomenon, including the ideal gas law and the first law of thermodynamics, while also considering fluid mechanics and heat transfer effects.
  • Experimental/applied
  • Vishwajeet describes an experiment involving the rapid release of oxygen and seeks to understand the theoretical pressure-time relationship.
  • Some participants suggest using the ideal gas law to relate pressure and temperature, indicating that a decrease in pressure would correspond to a decrease in temperature.
  • Others propose applying the first law of thermodynamics to analyze changes in internal energy over time, suggesting a stepwise approach to determine pressure changes.
  • Chet emphasizes the need to characterize the pressure drop versus flow rate relationship for the nozzle to derive a pressure function over time.
  • Curioso77 highlights the importance of fluid mechanics and suggests that the problem may involve complex dependencies, including heat transfer and compressibility effects.
  • Vishwajeet raises questions about using adiabatic versus isothermal equations for calculating pressure ratios during the gas release.
  • Some participants recommend studying isentropic flow to better understand the dynamics involved in the gas release process.
  • Vishwajeet notes discrepancies in his experimental data when compared to theoretical predictions, indicating that both isothermal and isentropic relations do not fully account for the observed behavior.
Participants express various viewpoints on the theoretical approaches to model the pressure-time relationship, with no consensus reached on a specific method or equation. The discussion remains unresolved, with multiple competing views and suggestions presented.
Participants acknowledge limitations in their approaches, including assumptions about adiabatic conditions, the complexity of fluid dynamics, and the potential influence of heat transfer from the surroundings on the system's behavior.
This discussion may be of interest to experimentalists, thermodynamics researchers, and those studying fluid mechanics and gas dynamics, particularly in the context of gas release processes and their theoretical modeling.
vishwanaya
Dear Friends,
I carried out an experiment of sudden release of oxygen (open nozzle) from an oxygen cylinder used for medical college and hospitals. I found that pressure drops quite rapidly and cylinder surface cools from outside such that water droplets accumulate on its surface. This experiment is carried out in an oxygen factory in Goa India. Now I do want to know what is theoretical relation between pressure and time in such a case.
Can anyone show me the steps to arrive at such an equation?
Vishwajeet, Goa-India.
You can probably describe this with the ideal gas law: PV/nk_B = T, since the cylinder volume is fixed, the decreasing pressure P means the temperature T in the cylinder must decrease also.
ideal gas equation pV = nRT = n^2 k_B T. Therefore, variation of pressure and square of mole quantity should decrease so that your suggestions stands true. Please go ahead to discuss any further clarification for my help.
Thanks for quick response Tobychev.
Hi vishwanaya. Welcome to the board. I went through this a few years back here. Basically, you need to apply the first law of thermodynamics to the vessel such that:
dU = Qin - Hout
Do this in small time steps to determine the change in internal energy of the oxygen cylinder over time. The internal energy and pressure equate to a temperature. Read through the other thread and see if you have any questions.
Best regards.
Hi Guys,
In my judgement, to get the pressure as a function of time, you also need to characterize the pressure drop vs flow rate relationship for the nozzle, and combine this with Q_Goest's recommendation.
Chet
Thanks Q_Goest.
Relationship between P and T is not explicitly given there.
Can you help me in deriving such an equation?
Vishwajeet
In my opinion, you must take into account the fluid mechanics involved in the process. If you try to relate pressure with time, you need to solve the pressure drop as transitory effect of fluid flow. This is a complex problem that could have more dependencies that pressure ratio. With enough pressure ratio, you can reach supersonic flow, or at least a mach number that justifies include air compresibility in the equations. If you want to be more accurate, you need include heat transfer also. The probe that your system is not adiabatic is the behavior that you are reporting in the exterior. As a first approach, you can assume incompresibility and adiabatic system, and solve Bernoulli's equation over time in order to have mass as a function of time inside the cilinder, pressure vs time and temperature vs time applying the equation for ideal gas. You can use a numeric method like euler looking for a solution of the differential equation.
I hope that this hel you.
Thanks Curioso77.
While using Bernoulli's equation for Gravitational head mgh_in will get canceled with mgh_out.
Under kinetic head, 1/2mv^2, m will be equal in and out. v_out will be 1 mach as max speed that can be attained by a shock wave. speed v_in should we assume equal to what?
Under pressure head, P_out will be assumed 1 atm in SI units. P_in will drop with release of the gas.
To calculate P_o and P_in ratio, should I use adiabatic equation (P_in V_in)^1.4 in stead of isothermal equal?
Regards,
Vishwajeet
vishwanaya:
v_in=0
I recommend you to read about isentropic flow in order to have a better understanding of the whole phenomenom. For example, you can read the chapter 4: Isentropic Flow, from "The dynamics and thermodynamics of compressible fluid flow", by Ascher Shapiro, a classic book. At least at a first approach, it should be work.
regards
release of O2 gas
curioso77 said:
vishwanaya:
v_in=0
regards[/QUOTE
Thanks Curioso77.
Vin is zero.
My question is about sudden release of O2 gas from cylinder 7 m^3 vol and ini pressure 150 kg/cm^2. Pressure-time relation. It involves polytropic states` knowledge and derivation. I am basically an experimentalist. I look forward to publish a paper with the help of a physics theoretician. I have taken P-t readings, plotted graph on origin software program. It clearly shows that with isotropic relations result deviates by about 33% from actual value. Even isentropic relation does not hold good since there must be some inflow of heat from surroundings. Can you help me? I will do experimental part. We will discuss other nitty-grittys if you are interested.
Regards,
Dr. Vishwajeet Goa India
  • · Replies 27 ·
9K
11K
  • · Replies 22 ·
