Prime Number Formulas: Find the Nth Prime
  • Context: Undergrad
  • Thread starter Thread starter hadi amiri 4
    Formula Numbers
The discussion revolves around the quest for a formula that can generate the nth prime number. Participants explore various mathematical approaches, including references to existing theorems and definitions, while also debating the efficacy and implications of such formulas in both theoretical and practical contexts.
  • Some participants inquire whether any formula exists that can produce the nth prime, with references to external websites.
  • There are claims regarding the behavior of the function H(m), particularly that it yields an odd prime when 2m+1 is prime, and 2 otherwise, based on Wilson's theorem.
  • Some participants suggest that if 2m+1 is composite, H(m) equals 2, leading to a discussion about the implications of this definition.
  • Concerns are raised about the practicality of calculating (2m)! for larger values of m and whether the proposed formula is necessary given Wilson's theorem already provides a primality test.
  • There are assertions that the formula does not effectively produce the nth prime, as finding the corresponding m requires trial and error.
  • Participants discuss the computational efficiency of various methods for testing primality, comparing trial division with other approaches.
  • Some express skepticism about the potential financial rewards of discovering a formula for the nth prime, while others note the historical significance of such a discovery in relation to cryptography.
  • There are claims that explicit formulas for the nth prime already exist, alongside a variety of algorithms for computing it.
  • Participants question why the focus is primarily on prime numbers rather than exploring numbers with a specific count of prime factors.
The discussion contains multiple competing views regarding the existence and effectiveness of formulas for generating the nth prime. There is no consensus on the validity of the proposed definitions or the practicality of the methods discussed.
Participants express uncertainty about the definitions and calculations involved in the formulas, and there are unresolved questions about the computational feasibility of the proposed methods. The discussion also highlights the complexity of prime number distribution and its implications for cryptography.
This discussion may be of interest to mathematicians, computer scientists, and cryptographers exploring prime number theory, algorithms for primality testing, and the implications of prime numbers in security systems.
hadi amiri 4
Doesnt m=10 give 21=3*7 ??
According to Maple, H(10)=2.
If you look at the formula closely, you'll notice that H(m) is going to be an odd prime whenever 2m+1 is a prime, and otherwise it's going to be 2. This follows from Wilson's theorem (2m+1 is a prime iff (2m)! + 1 = 0 (mod 2m+1)) and the behaviour of [itex]\left\lfloor\lfloor x \rfloor / x \right\rfloor[/itex]. It's really nothing special.
Please work on this formula and find all gaps in order to fin a formula for primes
Ah, so it's just a clever way to obscure a definition by cases, and is really just saying
[tex]H(m) = \begin{cases}<br /> 2m + 1 & 2m + 1 \textbox{\ is\ prime} \\<br /> 2 & \textbox{otherwise}<br /> \end{cases}[/tex]
I guess you're right, I must've had an error somewhere.
Are you saying then that one can test whether an odd number is prime by calculating this? Wouldn't that be faster than, say, trial division by primes less than its square root?
As long as (2m)! can be calculated (although it should be difficult for larger values of m), there is no need for the proposed formula, because Wilson's theorem already tests primality: if 2m+1 divides (2m)!+1 then 2m+1 is prime.
When (2m)! is difficult to calculate then the formula becomes difficult as well.
Using Hurkyl's definition for H(m),
H(m)=2 if 2m+1 is composite.
H(4) = 2, and for all k, H(4+3k)=2.
H(12)=2, and for all k, H(12+5k)=2,
H(24)=2, and for all k, H(24+7k)=2, etc.
This is Eratosthenes' sieve, and I know about one exact formula for primes which utilizes it: Riemann's solution for the prime counting function. What other formula can be found?
:confused: Why would you think any of those claims are true? Did you actually try to evaluate them for any value of k?
Sure doesn't look like it.
The range of H is
{3,5,7,2,11,13,2,17,19,...}={2,3,5,...}
so there is no problem.am I right?
H(m) = 2 if 2m+1 is composite.
When m = 4 + 3k, then 2m + 1 = 3(2k + 3) which is composite for all k. In fact, 3(2k + 3) gives all odd numbers > 9 that are divisible by 3.
Similarly for m = (p^2-1)/2 + pk where p is prime, because then 2m + 1 = p(2k + p), and so 2m+1 is composite, and so H(m) = 2.
Good call; I had the wrong definition of H in my head when I responded.
hadi amiri 4 said:
The range of H is
The formula is interesting (it has certainly attracted many responses in a short time), but it does not produce the nth prime as effectively suggested in the first entry in this thread.
For a given n, we don't know for what value of m we get H(m) = the nth prime, until finding it by trial and error by calculating H(m) for a certain range of m. For instance, if the first prime is 2 (n=1), we find it (first) when m=4.
Trial division on n takes [tex]O(\sqrt n)[/tex] arithmetic operations, or [tex]O(\sqrt n/\log n)[/tex] with precomputation of primes. With Newton's method and Karatsuba, this takes [tex]O(n^{0.8})[/tex] bit operations. Without pecomputation, this method takes only logarithmic space -- log n space for n, log n space for the calculation, and 1/2 log n space for a counter.
A quick way to calculate [tex]\lfloor(2m)!/(2m+1)\rfloor[/tex] is noting that if 2n+1 is composite, [tex]\lfloor(2m)!/(2m+1)\rfloor=(2m)!/(2m+1)[/tex]. But this is what we're trying to determine, so slower methods must prevail. Now there are methods for computing n! in [tex]O\left(n(\log n)^{2+\varepsilon}\right)[/tex] bit operations, but these require factorization of n -- again, what we want to avoid. So binary splitting gives the solution in time [tex]O(n^{1.585})[/tex], though with lots of logarithmic factors hidden in the big O.* After that the exponentiation must be performed, at cost [tex]O(\log n!)=O(n\log n)[/tex]. The space requirement for a literal computation is huge: [log]O(\log (2n)!)=O(n\log n)[/tex], an order of magnitude larger than trial division.
In conclusion, trial division is far superior, taking roughly the square root of the time and the logarithm of the space of this method.
* At several points I'm able to hide logarithmic factors between lg 3 = 1.58496... and the 1.585 I display; sneaky, eh?
guys if you all were able to generate a formula that gives the nth prime...you will be rich!...correct me if i am wrong but aren't security for top secret files as well as e-commerce based on the fact that really big prime numbers (they are set as encryption keys) cannot be factorized. So good luck...i thnk it is RSA algorithm that relies on prime numbers
While I doubt you would get rich(If you were thinking about the RSA factorization prizes, I'm sorry to tell you, but they stopped giving them out in 2007), but you would secure your place in history.
Yes, the RSA uses prime numbers to encrypt. SSL uses prime numbers as well. If some smart guy(or gal) figures out the distribution of prime numbers those would be dropped pretty quickly.
There already exist explicit formulas for the n-th prime, and a variety of algorithms for computing the n-th prime.
correct me if i am wrong but aren't security for top secret files as well as e-commerce based on the fact that really big prime numbers (they are set as encryption keys) cannot be factorized..
I should hope not -- I can factor such numbers in my head, no matter how big they are.
It's already known. The primes occur precisely when we have an integer that is not a multiple of smaller integers. :-p Aside from that obvious fact, there are bewildering array of bulk statistics known about the primes, and a great many more that are consequences of the Riemann hypothesis.
Why is the mathematical world so focused on prime numbers, why not the general case, to find all numbers with n prime factors?
1. There are lots of formulas that generate primes; creating a new one won't guarantee that you can get a paper published, much less than make you rich.
2. Many encryption algorithms rely on the hardness of factoring large semiprimes; factoring primes is, of course, trivial.
I don't think there's any push to find (general) prime numbers -- there are too many -- but to learn how to quickly factor a number into its prime factors. This is interesting because such a factorization is unique (up to order and units), though there is still interest in factoring into coprimes and partial factorization in general.
That's a good question, Kurret (IMHO), and that's a good reply, Greathouse (IMHO).
Kurret,
A few more thoughts, adding to what Greathouse said.
One reason there is a "focus" on "prime numbers" these days is the relation with the Riemann hypothesis. For example, if we can show that the error term in the prime number theorem grows at the order of the square root of n, then we will know that the Riemann Hypothesis is true. (ref: Barry Mazur's "error term" article in this issue of the BAMS; the equivalence was shown about 100 years ago).
So, this fact reduces your question to "why is there so much interest in the Riemann hypothesis"?
Well, first of all, the RH is a very old problem.
Second, if it is true, many intereesting and beautiful facts about nature will follow. (My viewpoint is that interesting mathematics describes interesting things about nature.)
Third, everything that is known about the RH gives the impression that we a re very close to solving it.
Fourth, it's been that way for about 100 years now, so why haven't we solved it? (Riemann even wrote down an exact formula for the error term in the prime number theorem. It would seem that all we have to do is analyze that formula.)
Fifth, numerical studies of the behavour of the zeroes of the zeta function on the critical line indicate that current techniques are inadequate to solve it. The behaviour of those zeroes is just too strange and too sbutle to get a handle on. Therefore, a solution would likely result in a significant advance in our understanding of mathematics in general.
Sixth, there is a million dollar prize for the person who resolves it.
Seventh, the name of the person who solves it is very likely to go down in history for a very long time.
On the other hand, as Greathouse pointed out, the question you ask is really of very high interest to today's mathematicians. One reason for that is IF we could find an effectgive algorithm to answer your question, THEN we would be a lot closer to finding an effective algorithm to factoring the product of two large primes in a short period of time. This would break RSA cryptography. It is highly likely that the proof would carry over to break discrete logarithm cryptography. It is quite possible that the proof would allow us to break elliptic curve cryptography.
The underlying mathematical meta-principle that you are touching on is that it is a lot easier to ask hard questions than it isw to ask "good" quesitons. A "good" question is a question that we have a hope of solving; that we feel that if we worked on it, we should be able to come up with something.
A small group of very good mathematicians are currently investigating the properties of numbers that are the product of a large number of small primes. The fact that that investigation is difficult (but doable) underlines just how hard the question that you ask probably is.
Another good example of a "hard" question is the question of whether or not there are an infinite number of Mersenne primes. For that one, there even exists a heuristic argument that there are an infinite number and it yields an asympototic estimate for how many there are!
And yet, as far as I know, nobody has any idea about how to get started on actually proving that there are an infinite number of them. Richard Guy also said this in his book "Open Problems in Number Theory" or something like that.
Oh, oh, oh, except the female star of the science fiction movie called "Proof." The "science fiction" in the movie is that she resolved the question about the finiteness of the Mersenne primes.
DJ
P.S. I welcome corrections, or even "that doesn't sound right" comments. That's how I learn.
I have good news the discoverer of this formula is going to publish a book that contains many results like defining the set of twin prime numbers a formula about producing nth prime and many other top results .
Well twin primes are old, at least as old as Sophie Germain (early 1800s) and probably older. I don't know hold long we've had explicit formulas for generating the primes, rather than just algorithms, but surely more than a hundred years.
What, then, are these "other top results"?
You're kidding, right? :confused:
why you don not respect others attempt
have you seen this book
why you are so judgemental
If you don't want people evaluating your hype, then don't post it. What else are we supposed to do with it? :-p
There is certainly no point in making qualifying statements about a claim that has not been presented in the necessary detail.
We haven't seen the book, that's why I asked what the "other top results" were. It's hard to respect results you don't know about.
  • · Replies 17 ·
  • · Replies 17 ·
13K
