Probability Current of a Wave Function
The discussion centers on calculating the probability current of the wave function ψ = Ae^i(kx - ωt) + Be^-i(kx + ωt). Participants confirm the complex conjugate ψ* is correctly derived as Ae^-i(kx - ωt) + Be^i(kx + ωt). They explore the derivatives of ψ and ψ*, leading to the expression for the probability current J, which simplifies to J = hbar/m[ψ∇ψ*]. There is debate over whether the current should equal zero, depending on the amplitudes A and B, and participants clarify the cancellation of terms in their calculations. The conversation highlights the complexity of quantum mechanics and the importance of careful mathematical manipulation.
leonmate
Find the probability current of Ae^i(kx - ωt) + Be^-i(kx+ωt)
Ok, to my understanding the probability current is the probability that you will find a certain particle as it moves with time, thus the probability of finding it changes with time. Quantum physics is a tricky one to grasp, I've got to say.
I have an equation for probability current:
J = (i*hbar / 2*m)( ψ∇ψ* - ψ*∇ψ)
So, I have figured that ψ = Ae^i(kx - ωt) + Be^-i(kx+ωt)
Thus ψ* = Ae^-i(kx - ωt) + Be^i(kx+ωt)
Not too sure if I have done the complex conjugate correctly here, I'm used to simple uses of it.. z = a + bi, z* = a - bi ... for example
Next, I'm assuming ∇ is del. I've used this function before, it works out as d/dx + d/dy + d/dz .. otherwise known as gradψ for this example.
I've tried differentiating it but ψ∇ψ* is some horrible maths, should i expect that? Wolfram alpha shows that d/dx of ψ is:
Ake^i(kx - ωt) * i'(kx - ωt) - Bke^-i(kx - ωt) * i'(kx - ωt)
I don't really know what i' is? and multiplying that out looks horrific and makes me think I've gone down the wrong path...
Could someone confirm for me that I have the complex conjugate correct?
if ψ = Ae^i(kx - ωt) + Be^-i(kx+ωt)
When I work it through with the equation above it looks very close to having lots of values cancel out and leave me with just [i*hbar / 2*m][ikA^2 + ikB^2]
But with the complex conjugate I have at the moment I'm a couple of negative signs away from that
You complex conjugate looks correct. What do you get for the derivative with respect to x of ψ*?
Alright, to my delight it does cancel down somewhat but not quite enough.
The derivatives I found were:
∇ψ = ikAe^i(kx-wt) - ikBe^-i(kx+wt)
∇ψ* = -ikA*e^-i(kx-wt) + ikB*e^i(kx+wt)
where the complex conjugate of A is A* and likewise for B*
Not sure if this is a necessary thing to do, but I found it somewhere and it seemed correct.
Anyway, I won't type it all out because it will take forever but basically I found that:
ψ∇ψ* - ψ*∇ψ = 2[ψ∇ψ*] = 2[-ikAA* + ikBB* +ikAB*e^2kxi - A*Be^-2kxi]
Now I've put it into my equation for J = (i*hbar / 2*m)( ψ∇ψ* - ψ*∇ψ)
The i and 2 cancel out and I'm left with:
J = hbar/m[ψ∇ψ*]
Don't really know where to go from here, some of the people on my course have told me that it should eventually result in zero.
That looks correct.
I don't think that's right. Certain terms in ψ∇ψ* will cancel certain terms in ψ*∇ψ when you combine ψ∇ψ* - ψ*∇ψ.
..., some of the people on my course have told me that it should eventually result in zero.
The term Ae^i(kx-wt) represents a wave traveling to the right with amplitude A. Be^-i(kx+wt) travels to the left with amplitude B. If |A| ≠ |B| would you expect the current to be zero?
When i calculate ψ∇ψ* - ψ*∇ψ i wind up with:
ψ∇ψ* = [Ae^i(a-b) + Be^-i(a+b)][-ikA*e^-i(a-b) + ikB*e^i(a+b)]
where a = kx , b = wt (for simplicity)
ψ∇ψ* = -ikAA* + ikBB* + ikAB*e^[i(a-b)+i(a+b)] - ikA*Be^[-i(a-b)-i(a+b)]
i(a-b)+i(a+b) = 2ai
-i(a-b)-i(a+b) = -2ai
ψ∇ψ* = -ikAA* + ikBB* + ikAB*e^2ai - ikA*Be^-2ai
Next,
ψ*∇ψ = [A*e^-i(a-b) + B*e^i(a+b)][ikAe^i(a-b) - ikBe^-i(a+b)]
= ikAA* - ikBB* - ikA*Be^[-i(a-b)-i(a+b)] + ikAB*e^[i(a+b)+i(a-b)]
= ikAA* - ikBB* - ikA*Be^-2ai + ikAB*e^2ai
So, when these values are subtracted:
[-ikAA* + ikBB* + ikAB*e^2ai - ikA*B^-2ai] - [ikAA* - ikBB* - ikA*Be^-2ai + ikAB*e^2ai]
This looks to me like it results in 2[-ikAA* + ikBB* + ikAB*e^2ai - ikA*Be^-2ai] = 2[ψ∇ψ*]
I follow your logic, however this is where the maths leads me. Perhaps I've made a mistake somewhere in this?
There is an easy way out for calculating probability current by using the eqn.
∇.j=-∂ρ/∂t,since every thing is dependent on x you can write it,
∂j/∂x=-∂ρ/∂t,where ρ=|ψ|2,and then integrate with respect to x.see if it helps.
Do the corresponding colored terms cancel? Maybe I'm overlooking a sign.
Feel like a fool for missing that, yeah it does cancel down nicely!
Thanks a lot for your help, got a few more tricky quantum questions so I will probably post if/when I get stuck on those haha
