Probability of finding a particle in a 1D Box
The discussion focuses on calculating the probability of finding a particle in a 1D box of size L within specific regions of size 0.01L at designated points. The correct approach involves integrating the probability density function, given by P=|\Psi(x,t)^2|, over the specified intervals. Participants emphasize the importance of substituting the wave function \Psi(x) into the integral before performing the calculations. The expected probabilities at the specified locations are 0%, 1%, 2%, 1%, and 0%. The conversation concludes with a participant expressing gratitude for the assistance received, indicating a clearer understanding of the problem.
scottnoplot
Determine the probability of finding a particle in a 1-D box of size L in a region of size 0.01L at the locations x = 0, 0.25L, 0.5L, 0.75L and L when it is in its ground state. As percentages
\Psi(x)=\sqrt{\frac{2}{L}}sin(\frac{nxPI}{L})
P=\Psi(x,t)^2
I'm not even sure if I've got the right equations there, I've tried loads of different ways of doing this and cannot get the right answers, which are 0%,1%,2%,1%,0%
Cheers
ok, finding probabilities means integrating the probability density - P=|\Psi(x,t)^2| - over parts of the box
try integrating over the whole box first, what does this give you?...
\int|\Psi(x,t)^2| = |\Psi(x,t)^3| /3
I think that's right.
Your answer cannot be a function of x, since you are integrating over x. Try substituting your expression for \Psi(x) from your first post before you integrate.
You need to integrate |psi^2| from x=0 to x=0.01L , from x=0.245L to 0.255L, etc
Try to plot psi, |psi^2| and the integral of |psi^2| from 0 to x (remember that the integral is the probabilty of finding the particle in the limits of integration...)
Thanks guys, got a bit of extra help and the penny has dropped now. cheers
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 30 ·
