Probably easy Laurent expansion question
The problem involves finding the Laurent expansion of the function f(z) = 1/(z^3 - 6z^2 + 9z) in the annulus defined by |z-3|>3. The discussion centers around the manipulation of the function to utilize series expansions.
  • Participants discuss using partial fraction decomposition and geometric series to find the Laurent expansion. There are attempts to express 1/z in a suitable form for expansion, and questions arise regarding the convergence of the series and the appropriate conditions for the geometric series.
Participants are actively engaging with the problem, offering suggestions and clarifications. Some guidance has been provided regarding the expansion of 1/z and the conditions for convergence, though there remains uncertainty about the correct approach and assumptions.
There is a noted concern about the convergence of the series and the implications of the region |z-3|>3 on the series expansion. Participants are questioning the validity of their manipulations and the conditions under which the series converges.
jinsing
Find the Laurent expansion of f(z)= 1/(z^3 - 6z^2 + 9z) in the annulus |z-3|>3.
none
I've been spending way too long on this problem.. I can't seem to think of a way to manipulate f to use the geometric series, other than getting something like 1/(1-(-3/z-3)) and arguing |z-3|>3>-3. Unless there's an other, better way to do this problem, could someone just let me know if I'm on the right track?
Start with a partial fraction decomposition.
Okay.. so now I have:
((1/9z) - (1/9(z-3)) + 1/(3(z-3)^2))(1/z)
I'm probably missing something completely obvious, but I'm still stuck at where I was before..
The only thing you are missing is that you almost have the answer! A Laurent expansion of f(x) "in the annulus |z-3|>3" is a power series in terms of powers of x- 3. You will still need to expand 1/z= 1/((z-3)+ 3).
Okay, so I expand 1/z = 1/((z-3)+3) = (1/(z-3)) * (1/(1-(-3/(z-3))) =
1 - 3/(z-3) + 9/(z-3)^2 - 27/(z-3)^3 + ...
Is this right? My issue keeps coming up with a way to use the geometric series while keeping |c|<1 (if 1/(1-c) = 1+c+c^2+...)
I think the answer requires that c= (z-3)/3 ..how does that make sense?
Maybe there is no Laurent expansion since the series doesn't converge?
You forgot the factor of 1/(z-3) you pulled out front.
No, you have it backwards. You're in the region where |z-3|>3, right? If you divide that inequality by 3 on both sides, you get |(z-3)/3| > 1, so with your choice for c, you'd have |c|>1, which is what you don't want. You want z-3 in the denominator so the terms get smaller.
Ah, that's what I thought, I was just doubting myself.. thanks so much for the help!
