Problem from Eisberg: Blackbody Radiation
5 replies · 3K views
raghav
In case of Cavity Radiation(Blackbody radiation) let [tex]\rho_{T}(\nu)d\nu[/tex] denote the energy density of radiation having frequency in the interval [tex]\nu[/tex] and [tex]\nu + d\nu[/tex].
Then we need to show that [tex]\frac{\int_{0}^{\lambda_{max}} \rho_{T}(\nu)d\nu}{\int_{0}^{\infty} \rho_{T}(\nu)d\nu} \approx \frac{1}{4}[/tex]
where [tex]\lambda_{max}[/tex] is the wavelength at which the radiation is most intense.
The obvious rela\evant equation is
[tex]\rho_{T}(\nu)d\nu = \frac{8\pi h\nu^{3}}{c^{3}}\cdot \frac{d\nu}{e^{\frac{h\nu}{kT}}-1}[/tex] . But the problem is the integration part. Can some one please help me with that?
on Phys.org
OK, so:
[tex]\int \nu ^3 \cdot (e^{\frac{h\nu}{k_b T}}-1)^{-1} \cdot \delta \nu[/tex]
Is the equation you need to solve, so you can use:
[tex]\int A \delta B = AB - \int B \delta A[/tex]
(from the differentiation product rule). There's a start. Let me know if it helped.
Sam :smile:
Oops, and you'll probably need this standard integral:
[tex]\int_0^{\infty} \frac{x^3}{e^x -1}\delta x = \frac{\pi^4}{15}[/tex]
Sam :smile:
Sam :smile:
Yes i could evaluate the denominator using the standard integral u have mentioned, however the Numerator is creating trouble. I have also tried a parts argument, doesn't seem to be taking me any where :cry:
Some1 please help asap
I can't do this without some assumptions, have you stated the WHOLE question from the start?
Sam
Yes I have indeed given all the necessary details the problem demands. Essentially my doubt boils down to evaluating the integral
[tex]\int_{0}^{a} \frac{t^{3}}{e^{t}-1}dt[/tex] ; [tex]a[/tex] being some constant.
