Problem in Convolution integral by fourier transformation
3 replies · 2K views
praban
Hello,
I am trying to numerically evaluate a convolution integral of two functions (f*g) using Fourier transform (FT) i.e using
FT(f*g) = FT(f) multiplied by FT(g) (1)
I am testing for a known case first. I have taken the gaussian functions (eq. 5, 6 and 7) as given in
http://mathworld.wolfram.com/Convolution.html
I am not using FFT but a naive implementation of FT. The problem I am facing is that the FTs are correct but convolution is not.
When I do inverse FT I do get back the 3 gaussians as given in the wolfram link. However, eq. (1) is not satisfied.
Is there any trick in eq. (1)? I would appreciate any suggestion.
thanks,
Praban
I am giving the details below (equation numbers are from my original posts, except the equation I have written below).
The sigma1 and sigma2 of eq. (5) and (6) are taken as 2.0 and 2.5
I am using 128 points in my discrete FT (values -63 to +64). Inverse FT of the FT of these gaussians give back those functions (although there are some error - about 10 to 20% - e.g I am getting 0.102 when the actual value is 0.117).
When I check FT(f*g) i.e. FT (gaussian of eq. (7)) = FT(f) multiplied by FT(g) (1)
the following happens
(1) the numerical values are same - however, FT(f*g) has alternate + and - signs for the numbers, while FT(f) mul FT(g) values are all positive
(2) If I change the limits - from -20 to +20 (still 128 points), alternate signs remain but now the numerical values also differ between two sides of equ. (1) and (2).
(3) I did the same with 512 points - results same as point (2) above.
I guess, that even FT of gaussian functions requires some fine tuning of spacing and number of points to choose (i.e. why 10-20% error is coming). However, in eq. (1), sign alternation part if not clear to me.
When I tried a function like exp(-kx)/x, my FT routine works fine (error less than 1%).
I would appreciate any help.
Praban
It's a waste of time thinking about your other problems, until you have fixed that one.
Try some simple functions where you know what the FFT should be. For example
a constant function
sine and cosine functions one period in the 128 points
an alternating sequence of values +1, -1. +1, -1., ...,
all the values zero except for one point.
When those you can do an FFT and an inverse FFT of those and the answers are correct to 5 or 6 significant figures, not 10% or 20%, then you can try debugging your convolutions.
