Why Does Using Specific Heat in a P-V Cycle Yield Zero Net Heat Transfer?
Using specific heat in a P-V cycle can lead to confusion regarding net heat transfer. The initial approach suggested that Q_net equals zero, which contradicts the observed net work done. It was clarified that different specific heats (c_v for constant volume and c_p for constant pressure) must be used for different processes in the cycle. The correct calculation revealed that Q_net equals 4P_i V_i, aligning with the thermodynamic principle that ΔE_int equals zero. This resolution highlights the importance of applying the appropriate specific heat values in thermodynamic calculations.
issacnewton
Hi
Here is a small problem. I already got the answer for part a. I have question about the part b.
For finding the heat energy input/output in each process from A to A, can't we use the
formula for the specific heat of the gas.
Q=m\, c \, (\Delta T)
But if we use that , I get Q_{net} =0 for the whole cycle.
That could not be correct, since I am getting net work done as
W_{net}=-4P_i V_i
Since in a thermodynamic cycle, we must have
\Delta E_{int} = 0
we deduce that
Q_{net}=-W_{net} = 4 P_i V_i
So what's wrong with my beginning approach to Qnet ?
IssacNewton said:
Hi
This is a good question! Without thinking through the details, I suspect the answer lies in the fact that for some paths cv is relevant, and for others cp is used. So adding up c?ΔT for the four paths doesn't result in zero, even if adding up the ΔT's results in zero.
Hi Redbelly, yes , you are right. Gases would have different c values for constant volume and constant pressure.
Redbelly
I got it right now. Here are different heats I got.
Q_{AB}=mc_v (2T_A)
Q_{BC}=mc_p(6T_A)
Q_{CD}=mc_v(-6T_A)
Q_{DA}=mc_p(-2T_A)
so we got
Q_{net}=4mT_A(c_p-c_v)
But for the ideal gas, we have the relation between specific heats of the gas (with repect
to mass , not molar specific heats )
c_p-c_v = \frac{nR}{m}
also at point A, we have
P_i V_i = nRT_A
using these two relations we get
Q_{net}=4mT_A\left(\frac{nR}{m}\right)=4(nRT_A) = 4P_i V_i
Q_{net} = - W
which is what I got earlier. So it makes perfect sense now. Thanks for the hint
  • · Replies 37 ·
  • · Replies 24 ·
