Problem Involving work, velocity, given Graph
1 reply · 1K views · last reply
Sade
An 8kg object is moving in the positive direction of an x axis. When it passes through x=0, a constant force directed along the axis begins to act on it. The figure gives it's kinetic energy K versus position z as it moves from x=00 to x=5.0 ; K(initial)= 30 . The forces continues to act. What is v when the object moves back through x=-3m?
I found the slope of the line, which is the force of the object: 30J/5m= 6N
(0,30J) is the y intercept so y=mx+b would yield the linear eq f(x)=6N(x)+ 30J
I plugged x=-3m into the equation to find the work at that point: f(-3)=6N(-3m)+ 30J
W=12J
f(0)=30 J= initial work
W= .5m(vf)^2- 30J
12J= .5(8kg)(vf)^2- 30J
4J=4(vf)^2
vf= 3.2 m/s
My answer was fairly close to the solution manual's (3.5m/s) but I'm still unsure if my reasoning was correct. Thanks so much in advance
Welcome to PF!
Does your slope have the correct sign?
Note that the graph represents the kinetic energy as a function of x, not the work. So, when you substitute a value for x into the linear equation, you get the kinetic energy at that value of x.
