Can you solve the Laplace transform of Bessel function of the first kind of order zero?
  • MHB
  • Thread starter Chris L T521
In summary, the Laplace transform of Bessel function of the first kind of order zero is 1/sqrt(s^2+1) or exp(-s)/sqrt(s^2+1). It is commonly used in mathematics for solving differential equations and systems of equations, as well as in signal processing and control theory. It can be simplified using various mathematical techniques and has numerous real-world applications in engineering, physics, and other scientific fields. The Laplace transform of Bessel function of the first kind can also be generalized to higher orders, resulting in a different expression but with similar principles and techniques for solving it.
Chris L T521
MHB
915
Thanks to those who participated in last week's POTW. I was glad to see the large turnout! (Smile)
Here's the problem for this week; I've decided to revisit the topic of Bessel functions.
Problem: The Bessel function of the first kind of order zero is defined by the following Taylor series:
\[J_0(t) = \sum_{n=0}^{\infty}\frac{(-1)^nt^{2n}}{(n!)^22^{2n}}\]
Let $\mathcal{L}\{f(t)\}=\displaystyle\int_0^{\infty}e^{-st}f(t)\,dt$ denote the Laplace transform of $f(t)$. Assuming that we can compute Laplace transforms term by term, show that
\[\mathcal{L}\{J_0(t)\} = \frac{1}{\sqrt{s^2+1}},\qquad s>1\]
and
\[\mathcal{L}\{J_0(\sqrt{t})\}=\frac{e^{-1/4s}}{s},\qquad s>0.\]
This problem was correctly answered by Sudharaka. Here's his solution.
\[\Rightarrow\mathcal{L}\{J_{0}(t)\}=\int_0^{ \infty}e^{-st}\sum_{n=0}^{\infty}\frac{(-1)^nt^{2n}}{(n!)^22^{2n}}\,dt\]Since the series representation of the Bessel function is a power series we can integrate term by term,\[{L}\{J_{0}(t)\}=\sum_{n=0}^{\infty}\left(\frac{(-1)^n}{(n!)^22^{2n}}\int_0^{ \infty}e ^{-st}t^{2n}\,dt\right)\]Since, \(\displaystyle\mathcal{L}\{t^{2n}\}=\int_0^{ \infty}e ^{-st}t^{2n}\,dt=\frac{(2n)!}{s^{2n+1}}\mbox{ for }s>0\)\[{L}\{J_{0}(t)\}=\sum_{n=0}^{\infty}\left(\frac{(-1)^n}{(n!)^22^{2n}}\frac{(2n)!}{s^{2n+1}}\right)~~~~~~~~~~(1)\]Now we shall show by mathematical induction, \(\displaystyle\frac{(-1)^n(2n)!}{(n!)^22^{2n}}=\binom{-\frac{1}{2}}{n}\mbox{ for each }n\in\mathbb{N}=\mathbb{Z}\cup\{0\}\)It is clear that the above statement holds for \(n=0\). Suppose the statement is true for \(n=p\in\mathbb{N}\). That is,\[\frac{(-1)^p(2p)!}{(p!)^22^{2p}}=\binom{-\frac{1}{2}}{p}\]Consider, \(\displaystyle\frac{(-1)^{p+1}(2(p+1))!}{((p+1)!)^22^{2(p+1)}}\)\begin{eqnarray}\frac{(-1)^{p+1}(2(p+1))!}{((p+1)!)^22^{2(p+1)}}&=&\frac{(-1)^p(2p)!}{(p!)^22^{2p}}\left(\frac{(-1)(2p+2)(2p+1)}{2^2(p+1)}\right)\\&=&\binom{-\frac{1}{2}}{p}\left(\frac{-p-\frac{1}{2}}{p+1}\right)\\&=&\binom{-\frac{1}{2}}{p+1}\end{eqnarray}Hence by mathematical induction, \(\displaystyle\frac{(-1)^n(2n)!}{(n!)^22^{2n}}=\binom{-\frac{1}{2}}{n}\mbox{ for each }n\in\mathbb{N}=\mathbb{Z}\cup\{0\}~~~~~~~~~~~~(2)\)By (1) and (2),\begin{eqnarray}{L}\{J_{0}(t)\}&=&\sum_{n=0}^{\infty}\binom{-\frac{1}{2}}{n}\frac{1}{s^{2n+1}}\\&=&\frac{1}{s}\sum_{n=0}^{\infty}\binom{-\frac{1}{2}}{n}\left(\frac{1}{s^2}\right)^n\\\end{eqnarray}\(\displaystyle\sum_{n=0}^{\infty}\binom{-\frac{1}{2}}{n}\left(\frac{1}{s^2}\right)^n\) is the Taylor series expansion of \(\displaystyle\left(1+\frac{1}{s^2}\right)^{-\frac{1}{2}}\mbox{ for }\frac{1}{s^2}<1\Rightarrow s>1\mbox{ (Since s>0)}\)\[\therefore{L}\{J_{0}(t)\}=\frac{1}{s}\left(1+\frac{1}{s^2}\right)^{-\frac{1}{2}}=\frac{1}{\sqrt{s^2+1}}\mbox{ for }s\geq 1\]Now we shall show that, \(\displaystyle\mathcal{L}\{J_0(\sqrt{t})\}=\frac{e^{-1/4s}}{s}\mbox{ where }s>0\,.\)\[J_0(\sqrt{t}) = \sum_{n=0}^{\infty}\frac{(-1)^nt^{n}}{(n!)^22^{2n}}\]\[\Rightarrow\mathcal{L}\{J_{0}(\sqrt{t})\}=\int_0^{ \infty}e^{-st}\sum_{n=0}^{\infty}\frac{(-1)^nt^{n}}{(n!)^22^{2n}}\,dt\]Since the series representation of the Bessel function is a power series we can integrate term by term,\[{L}\{J_{0}(t)\}=\sum_{n=0}^{\infty}\left(\frac{(-1)^n}{(n!)^22^{2n}}\int_0^{ \infty}e ^{-st}t^{n}\,dt\right)\]Since, \(\displaystyle\mathcal{L}\{t^{n}\}=\int_0^{ \infty}e ^{-st}t^{n}\,dt=\frac{n!}{s^{n+1}}\mbox{ for }s>0\)\begin{eqnarray}{L}\{J_{0}(t)\}&=&\sum_{n=0}^{\infty}\left(\frac{(-1)^n}{(n!)^22^{2n}}\frac{n!}{s^{n+1}}\right)\\&=&\frac{1}{s}\sum_{n=0}^{\infty}\frac{\left(-\frac{1}{4s}\right)^n}{n!}\\\end{eqnarray}Since, \(\displaystyle e^{-\frac{1}{4s}}=\sum_{n=0}^{\infty}\frac{\left(-\frac{1}{4s}\right)^n}{n!}\)\[\mathcal{L}\{J_0(\sqrt{t})\}=\frac{e^{-1/4s}}{s}\mbox{ for }s>0\]Q.E.D
FAQ: Can you solve the Laplace transform of Bessel function of the first kind of order zero?
1. What is the Laplace transform of Bessel function of the first kind of order zero?
The Laplace transform of Bessel function of the first kind of order zero is 1/sqrt(s^2+1). This can also be written as exp(-s)/sqrt(s^2+1).
2. How is the Laplace transform of Bessel function of the first kind of order zero used in mathematics?
The Laplace transform of Bessel function of the first kind of order zero is used in solving differential equations and systems of equations in mathematics. It is also used in signal processing and control theory.
3. Can the Laplace transform of Bessel function of the first kind of order zero be simplified?
Yes, the Laplace transform of Bessel function of the first kind of order zero can be simplified using various mathematical techniques, such as partial fraction decomposition or using tables of Laplace transforms.
4. What is the significance of the Laplace transform of Bessel function of the first kind of order zero in real-world applications?
The Laplace transform of Bessel function of the first kind of order zero has various applications in engineering, physics, and other scientific fields. It is used to model and analyze systems with oscillatory behavior, such as vibrating strings or circuits.
5. Can the Laplace transform of Bessel function of the first kind of order zero be generalized to higher orders?
Yes, the Laplace transform of Bessel function of the first kind can be generalized to higher orders by changing the order of the Bessel function. This results in a different Laplace transform expression, but the basic principles and techniques for solving it remain the same.
