Problem on Radiation Pressure
  • Thread starter Thread starter Mohammad Ishmas
33 replies · 3K views · last reply
Mohammad Ishmas
There is a Conical structure such that its base is completely reflecting and the tip of the cone which has a very small area and completely absorbent surface, if the light of same intensity is incident on the tip and on the base simultaneously then find the ratio of the force exerted by light at the base to the force exerted by it on the tip
F = (2I*A/c) for completely reflecting surfaces and F = I*A/C for absorbent surfaces , where I is the intensity and c is the speed of light and A is the area on which the light is being incident.
Question on radiation pressure
Mohammad Ishmas said:
Homework Statement: There is a Conical structure such that its base is completely reflecting and the tip of the cone which has a very small area and completely absorbent surface, if the light of same intensity is incident on the tip and on the base simultaneously then find the ratio of the force exerted by light at the base to the force exerted by it on the tip
Relevant Equations: F = (2I*A/c) for completely reflecting surfaces and F = I*A/C for absorbent surfaces , where I is the intensity and c is the speed of light and A is the area on which the light is being incident.
What have you tried so far? Please show your work.
I have figured out that the ratio will depend only on areas of the base and the tip since the intensity of the light is same, however I am clueless in finding the area of the base in terms of area of the tip or vice versa
The tip of a cone is a point, so its area is zero. Do you mean a truncated cone?
The question seems incomplete. You need to post the exact, complete original question including any diagram(s).
this is the original question itself, and by "very small area" it means a area which is infinitesimally small, also there are no diagram(s)
So what do you think the force (due to radiation pressure) on an infinitesimally small area will be?
Let us consider the infinitesimally small area to be 'dA' , then we can directly use the formula I have mentioned that is F = (I*A)/c (This is for completely absorbent surfaces, where I is intensity, A is area which in this case is 'dA' and c is the speed of light )
If the total area is infinitesimally small, then there is no integration to perform; the total force is infinitesimally small, i.e zero. A non-zero force can only arise for a finite area.
Are trying to solve a different problem requiring integration? Maybe this:
Diagram of a black cone with its point to the left and open circular base to the right, with arrows on the left pointing right toward the cone and arrows on the right pointing left toward it.
Yeah you are right the diagram would be like this , and it would require integration but how can I find the area of the base in terms of the area of the tip (basically the question has a pre made assumption that the tip has a area that is very small)
You cannot.
Not without additional information. Which you claim does not exist.
jbriggs444 said:
You cannot.
Can't we use integration ?? , the area of the tip will coincide to some area of the base. And what additional information would be required to find the area of base in terms of area of tip
The 'area of the tip' is zero. Do you mean the 'area of the curved side' (shown in black in the Post #8 diagram)?
I am sorry, the question actually says a that there is a Frustrum of a cone with the area of the top part (that I called tip earlier) being very small . I had assumed that area to be 'dA' , However how can I find area of the base in terms of dA ??
A diagram would have saved a lot of confusion! The area of the small face is small but finite - so you shouldn't represent it using 'dA'. That's misleading.
There is still too much missing information. What values (lengths and maybe angles) do you think are needed to answer the question?
I think I will need radius of both the base and the frustum (the top part), and the heights also. I am thinking of a approach to find the rate at which the area decreases as we move from bottom to top of the frustum of the ocne
If you have the radius of the base, you can calculate the area of the base, right?
If you have the radius of the frustrum, you can calculate the area of the frustrum, right?
Why would you need the height? We are not told how radiation affects the sides of the truncated cone. So knowing the area of the sides tells us nothing useful.
In the original question, radii and heights aren't given. We basically have to just derive a ratio of the forces , and the best approach I could think of was to just find the area of the base in terms of area of the frustrum. It would give us something in terms of either radii or heights , but how exactly do we do that ?
One approach when given a very badly formulated question (which, IMO, this is) is to present your own best-guess interpretation of the question and then answer that. Here’s my best-guess interpretation of the question:
A right conical frustum has two circular flat faces, A and B.
Face A is the larger, with radius ##R_A## and is a perfect reflector.
Face B, with radius ##R_B## is a perfect absorber.
As shown in the diagram, light of the same intensity, ##I##, is normally incident on faces A and B.
Diagram of a truncated cone with its smaller top face labelled B and larger bottom face labelled A, both drawn as blue ellipses, with downward arrows labelled I hitting B and upward arrows labelled I hitting A.
Find the ratio of the magnitude of the force exerted by light on face A to the magnitude of the force exerted by light on face B.
Can you answer that?
EDIT: 'force' changed to 'magnitude of the force'.
Yes this is the question, I am sorry for not giving the diagram as it was not there in the original question
That is still a very strange question. In practice, how would it be that the light at the sharp end is only incident on the flat face? The version you suggested in post #8 is both more reasonable physically and more interesting algebraically.
@Mohammad Ishmas , please post the original question exactly as given to you, whatever language it is in.
No it is not! In my version, the radii are given (##R_A## and ##R_B##) - you can use them in the answer. But in Post #17 you explicitly said:
There are too many conflicting statements. Can you clarify things by doing what @haruspex asked in Post ##20?
The original question is as follows -
A uniform beam of light falls on a frustum of a cone. The smaller top surface of the frustum is completely absorbent, while the larger base is perfectly reflective. The original cone, before being cut, had a total height H and a base radius R. The frustum was formed by removing the upper part of the cone, which had a height h from the tip to the top of the frustum. Find the ratio of the force exerted by the light on the base to the force exerted on the top surface.
I am also sorry for not posting it earlier but I couldn't as this was in a regional language
From this information one can calculate the radius of the frustrum, ##r##.
Can you see how? Can you show us the formula you come up with?
Yeah I can see that , we can use similar triangles to find that r = R(h/H)
It now sounds like there is only one beam of light. That makes previous descriptions wrong. Possibly the intended setup is this:
Diagram of a cone-shaped object with a black elliptical top and a curved base, with six downward arrows above it, labelled 'Perfectly absorbing top' and 'Perfectly reflecting base'.
This would make much more sense.
I found a solution using this value of 'r', I just plugged this value of "r" in πr^2 , then you would get a ratio of the two areas in terms of height, basically if the area of the base in A and area of top surface is B , then ratio A/B = (H/h)^2 , then we can just use the formulas to find the ratio of the forces
Did you take into account the difference in reflectivity?
Yeah I did , I used the different formulas for completely reflective and completely absorbent surfaces (for reflective surfaces the force just becomes twice). the final answer comes out to be , Fa/Fb = 2(H/h)^2
Ok. However, if the diagram in post #25 is accurate, the larger surface is partly shaded or displaced by the smaller one. But since the ratio is given as large, presumably we can ignore that.
Sorry but I didn't get you, what do you mean by , "the larger surface is partly shaded or displaced by the smaller one." ?
