Problem using Pulleys with Weight in Equilibrium
11 replies · 4K views · last reply
Tygra
Calculate angle of mast and the compression force in the mast
In the question
Dear all,
I have the following problem:
I need to find the compression "C" in the mast and the angle that the masts makes with the horizontal (X degrees).
I know that the tension in the ropes "T" are of the same magnitude on both sides of the pulley, but I am struggling with finding C and X.
Could someone help please?
If nothing is moving, all forces are in balance.
What have you done so far in terms of free body diagrams?
Hi Lnewqban,
this is how I attempt the question:
When I do the final algebra, I am way off.
Tygra said:
Hi Lnewqban,
Please share a Free body diagram of the hanging weight, and a separate FBD of the mast.
Lnewqban said:
It seems that the original diagram shows the top 45° angle in error, as its reference should be a vertical line rather than C.
So are you saying they did this on purpose?
Can I ask, how you would attempt this question?
No, I don’t.
Yes, you can: a free body diagram would be my very first step.
Lnewqban said:
No, I don’t.
So it must be a typo in the book? This problem is from a book.
Here is my free body diagram:
Is this correct?
Is this correct?
FBD of what? You isolate the hanging mass. Forces of weight ##W## and tension(s) ##T## act on it. You use it to find ##T## in terms of ##W##. Thats one FBD. The other is a Free body diagram of the member ##C##. You isolate the mast from the external surroundings. Tension forces, and reaction forces at the hinge should be shown. You use both component equations simultaneously to find the angle ##X##.
Thank you. I have it now. I think I was making it more complicated than what it was.
Is this correct?
Yes, it must be a typo.
Otherwise they would be giving away angle x as being 90° (45+45+90=180), which is an incorrect value.
In order to properly calculate T, you need to consider the “Y” formed by T, T and 5 kN.
In this case the “Y” is symmetrical and the value of T is the same on the left and the right sides, but it is not always that way.
Hope you have checked the example in the link previously posted.
