Problem with finite diffence method
  • Thread starter Thread starter zeynepkisa
    Finite Method
The discussion centers on solving a nonlinear equation using the finite difference method, specifically addressing the challenges posed by derivative boundary conditions. The equation in question is u'' + 3*u^2 * (1/sin^2(x)) = 2.5, with boundary conditions u'(1) = 0.95 and u(2) = 0.83, and a step size of h = 0.25. A suggestion is made to treat the boundary condition as an interior point by introducing a fictitious boundary point, which allows for the formulation of a system of nonlinear equations. The implementation of a loop structure to solve these equations is recommended, with the Newton method proposed as a strategy to handle the non-linearity. This approach aims to facilitate the numerical solution of the problem effectively.
zeynepkisa
I have been trying to solve this problem for hours and hours but derivative boundary condition makes the it very hard. can anybody help me about nonlineer eq. solution with finite difference??
question is:
u'' + 3*u^2 *( 1 / (sin^2(x)) =2.5
BCs:
u'(1)=0.95
u(2)=0.83
h=0.25
(radian for sin function)
Exactly how are you applying "finite difference"? Are you assuming a linear solution overe each interval?
As for the boundary condition, since it involves a derivative, you should regard it the actual left boundary as an interior point.
Thus, introduce a fictitious boundary point x_{0}=1-h[/tex]<br /> and you have n+1 points x_{0}, x_{1}=1,\cdots{x}_{n}=2[/tex]&lt;br /&gt; &lt;br /&gt; The differential equation should be satisfied at all interior points, so that you have n+1 non-linear equations like this:&lt;br /&gt; \frac{u_{2}-u_{0}}{2h}=0.95, u_{n}=0.83&lt;br /&gt; and:&lt;br /&gt; \frac{u_{i+1}-2u_{i}+u_{i-1}}{h^{2}}+3u_{i}^{2}\frac{1}{\sin^{2}(x_{i})}=2.5, i=1,\cdots{n-1}&lt;br /&gt; &lt;br /&gt; Now, you are ready to see how to implement a loop structure to actually solve this system approximately..
thanks for your attention
Have you decided upon a strategy to take care of the non-linearity?
yes Newton method
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
