Problem with relationship of mass and radius with time in centripetal force
The discussion revolves around an experiment aimed at understanding the relationship between mass, radius, and the period of time in circular motion, specifically in the context of centripetal force. The original poster presents lab data from two experiments, one focusing on mass and period, and the other on radius and period.
  • The original poster attempts to derive expressions relating mass and radius to period based on experimental data but expresses uncertainty about the relationship involving radius. Participants inquire about the specific mass being varied and the meaning of the uncertainties noted in the data.
Participants are actively questioning the setup and data interpretation, with some providing suggestions for further analysis. The original poster acknowledges the presence of uncertainties in their measurements and seeks clarification on deriving a formula for the radius and period relationship.
There are mentions of systematic errors due to the experimental setup, and the original poster clarifies that the experiment is not a pendulum. Uncertainties in measurements are noted as part of the data presentation.
805906000
We did a experiment, and the aim was to find out that relationship between mass and radius with period of time in the circular motion..Although I know the formula for centripetal force, but I am not sure about what the expression should be
The lab data :
Table 1: 1st experiment : relationship of mass and period
Mass Average time for 20 revolutions (+ 0.5 s) Period (T/20) For 1 revolution
1 25 15.355 0.76183
2 50 12.315 0.61575
3 100 7.53 0.365
4 150 6.66 0.333
5 200 5.635 0.28175
Radius: 35 cm (+ 5cm)
For this one I kind of get the expression, which is t= 1/√m times √4radius pie square (which the value is about 4) so 1/ root of mass and times 4.
Table 2: 2nd experiment: relationship of radius and period
Radius Average time for 20 revolutions Period (T/20)
For 1 revolution
1 10 6.595 0.32825
2 20 7.60 0.38
3 30 8.175 0.40875
4 40 9.35 0.47525
5 50 10.615 0.531
Mass: 25g (+ 1 gram)
And this one, I have not idea :confused: about the relationship of radius and period, can anyone help me out with this ? Thanks a lot!
p.s. the lab has systematic errors, since the angle can't be horizontal, cause we swing the object by hand.
In the experiment, which mass is being varied? The mass of that's being whirled around, or some counterweight?
What do these cryptic messages mean:
"Radius: 35 cm (+ 5cm)"
"Mass: 25g (+ 1 gram)"
Have you plotted your results?
The radius is the same for all the first trials(for determining the relationship of mass and time), and the mass is also the same for all the second trials(for determining the relationship of radius and time)
But what are "+ 5cm" and "+ 1 gram"? Are these meant to represent uncertainties in their values?
this might help you:
http://en.wikipedia.org/wiki/Pendulum
also, I'm sure you were supposed to use some kind of computer program (may be Excel) or were given a system to average out the numerous results you got and their errors, so you can get a single representative result (via theory) and it's error.
Thanks for the reply;
-Yes,The + 5cm/1 gram are uncertainties
-No,Excel cannot figure out any formula
-The experiment is not a pendulum, it is rather looks like: http://www.stmary.ws/high school/physics/home/lab/Centripetal_Force_Lab.htm
Actually,I would like to just find out the relationship between time and radius supporting by data and deriving some kind of formula, like the one I kinda figure out for the first one about mass and time (t= 1/√m times √4radius pie square, which is derive from centripetal formula)
Your uncertainties should probably look something like
R +/- 5cm
M +/- 1gm
To find your relationship between Radius and Period (for the second experiment), you'll have to write out the equation which equates the centripetal force with the weight of the counterweight, and isolate the desired terms. You may need to use another expression to express the velocity in terms of the period and radius.
  • · Replies 17 ·
9K
9K
