Problem with the Finite Element Method applied to Electrostatics
6 replies · 4K views · last reply
Alan Lins Alves
Hi!
I have a code that solve the poisson equation for FEM in temperature problems.
I tested the code for temperature problems and it works!
Now i have to solve an Electrostatic problem.
There is the mesh of my problem (img 01).
At the left side of the mesh we have V=0 (potencial).
There is a line charge located in (0.5,0) with charge density λ=1/(4*pi).
The poisson equation for electrostatics is:
Poisson equation written as nabla squared V sub rho equals negative rho over epsilon, with rho in the numerator and epsilon in the denominator.
My dificulty is how to solve it for a line charge (what is the best equation for ρ). I used the Dirac delta, and some aproximations for delta function but my code has wrong results.
  • Triangular finite element mesh on a rectangle from x=0 to 1 and y=-1 to 1, with the left edge marked V=0 and a red dot labelled lineCharge at (0.5, 0).
  • Poisson equation written as nabla squared V sub rho equals negative rho over epsilon, with rho in the numerator and epsilon in the denominator.
wow
it's been fifty+ years and the term "Dirac delta" is unfamiliar
and in my day we didn't have computers with precoded solutions .
In slide rule days we'd integrate along the line.
sorry i can't be more help.
old jim
Hi,
then how did you specify a pointlike heat source ?
jim hardy said:
wow
old jim
Ok,
Thanks old Jim!
BvU said:
Hi,
Equation: second partial derivative of T(x) with respect to x, equals minus Q over K, a one-dimensional Poisson equation for temperature.
This is the Poisson equation for temperature problem.
Note that temperature is in left side of equation.
  • Equation: second partial derivative of T(x) with respect to x, equals minus Q over K, a one-dimensional Poisson equation for temperature.
Alan,
I've done a lot of electrostatic calculations, analytical, numerical and FEA. However, I don't quite understand your question.
Could you elaborate on it? Draw a picture without a mesh to start with.
Are you trying to calculate the field of a charged wire next to a ground plane?
