Problem with vector field proof
9 replies · 2K views · last reply
Roidin
Suppose that F and G are vector fields and that F-G = ▽μ for some real-valued function μ(x,y). Prove that
∫ F.dx = ∫ G.dx for all piecewise smooth curves C in the xy-plane
I just need some help in getting started really. Thanks
If ##dx## is a scalar, what does ##\vec F \cdot dx## mean? Have you stated the problem correctly? Is C a closed curve?
Thanks LCKurtz,
F.dx is the line integral of the vector field and yes C is closed.
Roidin said:
Thanks LCKurtz,
That's unusual notation. And since it matters that C is closed, don't you think it would have been good to mention that?
Let's call ##\vec H = \vec F -\vec G##. So say ##\vec H = \langle h_1,h_2\rangle## and you are talking about$$
\oint_C \vec H \cdot d\vec r =\oint_C h_1\, dx + h_2\, dy$$So now if you use ##\vec H(x,y) =\nabla \mu(x,y)## what happens?
Hi I am doing a similar problem so sooner than start a new thread...
[itex]\oint_C \vec H \cdot d\vec r =\oint_C \frac{dμ}{dx}\, dx + \frac{dμ}{dy}\, dy[/itex]?
Yes. Now do you see how to argue that it is zero?
No. in a word.
I thought i might be able to work something out using greens theorem(as the curve is closed) but its not working out...
gtfitzpatrick said:
No. in a word.
Green's theorem is what you want. What do you get and why don't you think it works?
[Edit]I have to go for a couple of hours. I'll check back and see if you have it by then.
[itex]\oint_C \vec H \cdot d\vec r =\oint_C \frac{dμ}{dx}\, dx + \frac{dμ}{dy}\, dy[/itex] = [itex]\int\int\frac{d^2μ}{dxdy}-\frac{d^2μ}{dxdy} dxdy = 0[/itex] but this can only be true if [itex]\oint F.dr = \oint G.dr[/itex] qed?
Yes. It would be more clear if the left side had started with$$
\oint_C \vec F\cdot d\vec R -\oint_C\vec G\cdot d\vec R =\oint_C (\vec F-\vec G)\cdot d\vec R=\oint_C\vec H\cdot d\vec R =\ ...$$
