Which Program is Best for Plotting 3D Trajectories?
For plotting 3D trajectories, MATLAB is recommended due to its standard use in the dynamics community and the availability of the plot3 command, which simplifies the process. Alternatives like FreeMat and Octave are open-source options that mimic MATLAB's functionality. Users with experience in programming languages such as Java or VB Script can easily adapt to MATLAB. The discussion highlights the importance of having features like adjustable parameters for wind and air resistance in the graphical output. Overall, MATLAB is the preferred choice for creating and saving 3D trajectory plots efficiently.
Adoniram
Howdy folks,
I have been given the opportunity to do some extra credit for my mechanics class. As an assignment, my prof would like to see a 3D trajectory plotted via a program (like Python).
My basic assignment is to plot the trajectory of a soccer ball after it has been kicked. I don't need help with the physics equations, but I need to know what programs I can use and if one is better than the other. No worries learning the coding language, I have a lot of experience with Java, vb script, etc...
Ideally, I'd like to use a program that has a simple 3D plot of trajectory, and it would be even better if I could save the results as an independent program. If not, no big deal. Also, it would be superb if I could put in switches in the graphical output for things like turning wind on and off, air resistance, etc... If not, I'm sure I can just write multiple programs for each instance.
Thanks!
I would use Maple (since that's the one I have experience with) or something equivalent to it.
MATLAB is generally the standard in the dynamics community. FreeMat and Octave are open source clones of MATLAB.
There is a plot3 command in MATLAB that will do what you want.
Here's an example MATLAB simulation of a mass attached to a spring that behaves as a pendulum; its equations of motion are:
<br /> \begin{align*}<br /> \ddot{r} &amp;= r\dot{\theta}^2 - \frac{k}{m}(r-l) \\<br /> \ddot{\theta} &amp;= -\frac{2\dot{r}\dot{\theta}}{r}<br /> \end{align*}<br />
Code:
[i]%% Example simulation of a dynamical system.[/i][/color]
r0 = 1;
l = 1;
rdot0 = rand[/color](1,1);
theta0 = rand[/color](1,1);
thetadot0 = rand[/color](1,1);
x0 = [r0 theta0 rdot0 thetadot0]'[/color];
[t x] = ode45(@pendulum, [0 100], x0);
r = x(:, 1);
theta = x(:, 2);
x = r .*[/color] sin[/color](theta);
y = r .*[/color] cos[/color](theta);
plot(x, y, x(1), y(1), '+g'[/color], x([b]end[/b][/color]), y([b]end[/b][/color]), 'xr'[/color], 'MarkerFaceColor'[/color], 'r'[/color], 'linewidth'[/color], 3);
    tl = title('X-Y Position of Spring-Mass Pendulum'[/color]);
    xl = xlabel('x'[/color]);
    yl = ylabel('y'[/color]);
    set([tl xl yl], 'fontsize'[/color], 16);
    legend('Path'[/color], 'Start'[/color], 'End'[/color], 'Location'[/color], 'NorthEastOutside'[/color]);
Code:
[b]function[/b][/color] [/color] xdot = [/color] pendulum[/color](t, x)
    [/color]m = 1;
    k = 1;
    l = 1;
    r = x(1); theta = x(2); v = x(3); w = x(4);
    xdot = [v;
            w;
            r .*[/color] w.^[/color]2 -[/color] k/[/color]m *[/color] (r -[/color] l);
            -[/color]2 *[/color] v *[/color] w /[/color] r;
[b]end[/b][/color]
What you want to do will be much simpler than this, but this example should give you a taste of MATLAB.
