Programming a Diffraction Pattern by the (pseudo?) method of images
39 replies · 7K views · last reply
3D surface plot in MATLAB style, colored blue to yellow by height, with one tall central peak about 14000 high and a flat blue surrounding sheet with dips near the edges; axes labeled x-axis, z-axis and flux through arbitrary plane parallel to xz-plane.
I have no idea what I just did (I literally just played around with moment values and position) but I'm going to review my script to make sure it's not physical nonsense. Hopefully it's not because I'm really happy with a seemingly cylindrically symmetric (positive) peak with smaller ripple peaks around it. This is definitely progress.
Note that my previous picture that I was ecstatic about had a peak value of 0 which is not desirable.
Also, my peak value is about 10 times the second peak which is probably not typical of diffraction.
I'll have to figure out a way to "tighten" my parameters but this overall shape is good.
3D surface plot in MATLAB style, colour-mapped blue to yellow, showing a central peak surrounded by concentric ring-like ripples that decay outward; z-axis scaled by 10^-11, x and y axes run from -2500 to 2500.
Just for thrills I Lorentz transformed the fields of an oscillating dipole in the z-direction (while traveling in the x-direction) and took the flux through a ##x = constant## plane. I think this is an improvement?
I made ##\beta = 0## and I get the same thing pretty much so that was pretty much fruitless.
@TSny may I ask a question about spherical harmonics? In the previous thread where you helped me extensively we were able to produce the shapes made by ##\left|Y^1_1 \left( \theta, \phi \right) \right|^2 ## and
##\left|Y^1_2 \left( \theta, \phi \right) \right|^2##. I'm interested in creating
##\left|Y^0_1 \left( \theta, \phi \right) \right|^2## if possible with some distribution of charge/current. From my very cursory understanding of things it is somewhere between a monopole and a typical dipole?
I believe this could give my a locally spherically symmetric surface and therefore a cylindrically symmetric flux pattern indicative of diffraction through a small circular aperture. Maybe I'm barking up the wrong tree.
Grid of 3D surface plots of |Y(θ,φ)|² spherical harmonics, labelled by degree and order, from Y₀⁰ (a sphere) through Y₁⁰, Y₁¹, Y₂⁰, Y₂¹, Y₂², Y₃⁰, Y₃¹, Y₃², and Y₃³, shown as lobed, bulging shapes of increasing complexity.
I don't think it's possible to get a pure spherical harmonic potential for radiating systems. It seems by definition that each multipole is a sum of various spherical harmonics.
3D surface plot in MATLAB style, colour-mapped from blue to yellow, showing a central peak that steps down into concentric rings with small side ripples; axis values run from -2500 to 2500 and the vertical scale is labelled in units of 10^-6.
Getting closer need to get rid of that spiral like pattern.
The last picture was from a rotating dipole. Anyone have any ideas how I can mess around with frequencies to get rid of the spiral? Maybe introduce a rotating magnetic dipole in the orthogonal plane?
3D surface plot in MATLAB-style colormap of a diffraction-like intensity pattern: a central peak with concentric ring-like shoulders and oscillating side lobes, axis ticks from -2500 to 2500 and z-axis scaled by 10^-8 up to 2.5.
Getting so close but doing so by arbitrarily making electric and magnetic dipole moments complex in different ratios. If I get a good result I'll have to reconcile it physically.
@hutchphd @etotheipi @TSny
I had some serious misconceptions about the dipole approach to diffraction (or more generally "aperture coupling") . The image dipoles on either side of the infinite (closed off) conducting sheet are supposed to yield total power through the aperture, it is not supposed to recover the Bessel function. Apparently for many applications total power is the most important parameter as opposed to its distribution.
The first two sections of this paper offer an excellent explanation if you're interested.
https://www.tandfonline.com/doi/full/10.1080/02726343.2011.590960?scroll=top&needAccess=true&
The values of the dipoles can be chosen such that the structure on the left absorbs power and the structure on the right emits the same amount of power thus simulating power through an aperture.
  • Diagram of equivalent sources for aperture coupling: a vertical conducting sheet with fields E1,H1 on the left and E2,H2 on the right, dashed surfaces S1 and S2 around the sheet, electric currents Je1, Je2, magnetic currents Jm1, Jm2, and equivalent dipoles -Ma, Pa and Ma, Pa on either side of the aperture.
Thanks for the link. I see that his primary reference is to
Theory of Diffraction by Small Holes
H. A. Bethe
Phys. Rev. 66, 163 – Published 1 October 1944
which is, as always, a nice treatment. It was never clear to me the range of applicability of Bethe but he does say it is for holes small compared to wavelength but then he generalizes some. I think your assessment is on point.
H. A. Bethe
I think Bethe deals with the small hole limit whereas the Kirchhoff Integral deals with the large hole limit. In the Bethe limit I think the hole is so small that the electric field is essentially constant over its extent thus resembling a linear relationship ##\vec{p} = (constant) \vec{e}## or some diagonal polarizability tensor.
Bethe mentions in his paper that the total radiation/power from the Kirchhoff Integral to the his results should differ on the order of ##\frac{a^2}{\lambda^2}## but reading his results more carefully I think there is a slight difference.
He says the Kirchhoff Integral yields ##\vec{H}## on the order ##k a^2## whereas his solution yields ##\vec{H}## on the order of ##k^2 a^3##.I presume the same goes for ##\vec{E}##If so the radiation intensity is related to the square of these values
##\frac{Kirchhoff}{Bethe} = \frac{\left(ka\right)^2}{\left( k^2 a^3\right)^2} = \frac{k^2 a^4}{k^4 a^6} = \frac{1}{k^2 a^2} = \frac{\lambda^2}{4 \pi^2 a^2}##
Basically I think the Kirchhoff Integral should differ from the Bethe solution by the following
##Bethe = \frac{4 \pi^2 a^2}{\lambda^2} \left( Kirchhoff \right)##
I hope I did that math right.
