Projectile Fired Against Sloped Surface
  • Thread starter Thread starter CzarValvador
    Projectile Surface
2 replies · 3K views · last reply
CzarValvador
Lets say a Projectile is fired at an angle (theta) from the Horizontal. The Catch is that the place it was fired from is a hill sloped angle (phi) against the horizontal. The question is what are the angles are which you can get the highest Range (Range = not the Farthest Horizontal Distance, but the farthest distance along the slop).
Hint: If (phi) is 60, then (theta) is 15.
I've tried doing this problem multiple ways. I set the slope length as D. Making the Vertical displacement vector at the end -Dsign(phi), and the Horizontal Displacement Vector Dcos(phi).
I then used the basic Kinematics equations and combined them. I solved for t under the horizontal displacement and plugged in what I got into my vertical displacement equation, but I keep going nowhere because I have a bunch of sines and cosines with theta and phi.
Can anyone save me?I understand if the ground was flat, the answer would be 45 Degrees as the firing angle, but... with the slope it is VERY different.
Welcome to PF!
Hi CzarValvador! Welcome to PF! :smile:
(have a theta: θ and a phi: φ :smile:)
Show us your θ and φ equations … there's probably a simple trig trick for solving them (like the sin(A+B) rule). :wink:
Hey, thanks. Appreciate the help, but I was a little too late in figuring it out and turned it in. I had the physics TA solve it.
All he did was found where the equation of the height of the Slope, and an Equation for the height of the projectile and set them equal to each other.
Thanks for the help, expect more questions from me throughout the year :P
