Projectile Motion and maximum height
In summary, the projectile reaches a maximum height of 61 m when it is launched with a speed of 40 m/s and an angle of 60 degrees above the horizontal.
wowdusk
A projectile is launched with a speed of 40 m/s at an angle of 60 degrees above the horizontal. Use conservation of energy to find the maximum height reached by the projectile during its flight.
KEi+PEi=KEf+PEf
i am not sure where vf would come from. Would it be just Vi*cos(60)?
I am not sure why that makes sense.
Does Vix=Vf?...and why?
KEi+PEi=KEf+PEf
Assume your potential energy is 0 when you launch and your kinetic energy in the y direction is what? 1/2*m*Viy2?
And at the height it has no vertical kinetic energy and the potential energy is what?
What is the vertical component of V? (Hint: it's not Vi*cos(60))
why do i need the vertical component of Vi
I don't know how to find the V at the heighest point...
At the heighest point is the V in vertical direction 0 anyway?
I think i solved this out...i got 61m?
Yes your final V is 0.
But your initial V is the vertical component of V, as that is the component of V that is affected by gravity ... you know, where that potential energy is building.
Thank you...can you check if my answer is right?
1. What is projectile motion?
Projectile motion is the motion of an object that is launched or thrown into the air, and is affected by both gravity and the initial velocity of the object.
2. How is the maximum height of a projectile determined?
The maximum height of a projectile is determined by the initial velocity of the object, the angle at which it is launched, and the force of gravity acting on the object. These factors can be calculated using mathematical equations to determine the maximum height of the projectile.
3. What is the formula for calculating the maximum height of a projectile?
The formula for calculating the maximum height of a projectile is h = (v2sin2θ) / (2g), where h is the maximum height, v is the initial velocity, θ is the launch angle, and g is the acceleration due to gravity.
4. Can the maximum height of a projectile be greater than the initial height?
Yes, the maximum height of a projectile can be greater than the initial height if the launch angle is greater than 90 degrees. In this case, the object would follow a parabolic path and reach its maximum height before falling back to the ground.
5. What factors can affect the maximum height of a projectile?
The maximum height of a projectile can be affected by various factors such as the initial velocity, launch angle, air resistance, and the force of gravity. Other external factors such as wind and air density can also affect the maximum height of a projectile.
21K
