Projectile Motion: Determining Maximum Height and Velocity
The discussion centers on the physics of projectile motion, specifically determining the maximum height and velocity of a ball thrown with an initial velocity of <5,8,0> m/s. At maximum height, the vertical component of the velocity (vy) is 0 m/s, while the horizontal component (vx) remains constant at 5 m/s. The ball's total velocity vector at maximum height is therefore <5,0,0> m/s. The conversation clarifies misconceptions about velocity and acceleration in projectile motion.
  • Understanding of projectile motion principles
  • Familiarity with vector components of velocity
  • Knowledge of the Momentum Principle
  • Basic concepts of kinematics
  • Study the equations of motion for projectile motion
  • Learn about the effects of air resistance on projectile trajectories
  • Explore the concept of energy conservation in projectile motion
  • Investigate the use of simulation tools for visualizing projectile motion
Students studying physics, educators teaching projectile motion concepts, and anyone interested in understanding the dynamics of objects in motion.
Lemniscate
A small dense ball with mass 1.5 kg is thrown with initial velocity <5,8,0> m/s at time t= 0 from the origin (<0,0,0> m) Air resistance is negligible.
When the ball reaches its maximum height, what is its velocity?
Momentum Principle
Average Velocity
Though I have an idea of how to approach some of the questions regarding this problem, I have not been able to understand the following:
How do I know what the maximum height the ball reached is?
What do you know about an object that reaches its maximum height?
Think about what occurs to the motion of the ball at and around that time frame.
It's speed is 0, so the velocity (vector) would be <0,0,0> m/s at its max ht...?
dude the maximum height will be reached when the object has reached the distance which can be covered by throwing it at that angle, why should this be so confusing
The velocity vector will not be 0 at maximum height it would be the same, only direction of resultant will change based upon the energy that a body spends opposed to the acceleration.
That would be correct if the ball was thrown straight up, in a 1-D situation, without an x component to the velocity.
According to your question the ball was thrown with an initial velocity of <5,8,0> m/s. If at the maximum height the ball is not accelerating vertically, then (as we concluded) the vy is 0m/s.
Now reobserve the maximum height of the ball. After reading this, what are you left with?
The x-component of the velocity at its max ht is the same as the initial and the y-component of this vector is 0 since the ball is not acceleration vertically. Yes?
I have to apologize on my previous wording, the ball is accelerating vertically, but the velocity is just 0. If it wasn't accelerating, then in it would just float there in the air. That is the point where the velocity that is positive, and thus rising in position, changes to negative, and thus begins to fall back towards the ground. So you're somewhat correct.
Correct. There is no acceleration in the horizontal direction, thus the x component of the velocity remains constant. That is the only velocity vector, and thus is your velocity.
So, just to make sure, my velocity is <5,0,0> m/s at this point?
Thank you for your help, by the way. :)
Yup! =)
  • · Replies 39 ·
  • · Replies 22 ·
