Projectile Motion of a Jet Fighter: Calculating Velocity, Energy, and Power
A jet fighter with a mass of 3 tons ascends to 10,000 meters in one minute, with horizontal and vertical velocity components of 241 m/s and 139 m/s, respectively. The angle of travel is calculated using the tangent function, resulting in approximately 30 degrees. The speed is determined using the Pythagorean theorem, yielding a value of about 278.2 m/s, which differs from the expected 27.8 m/s due to a misunderstanding in the calculation. Kinetic energy is computed using the formula KE = ½mv², but confusion arises regarding the correct velocity value, while potential energy is correctly identified using PE = mgh.
JamalJenkins
A jet fighter of mass 3t climbs from ground level to a height of 10,000m
in one minute. At that time it has a horizontal component of velocity
of 241m/s and a vertical component of velocity of139m/s. find
(A) the direction in which it is travelling
(B) the speed
(C) its kinetic enregy
(D) its increase in gravitational potential energy
(E) the power delivered by its engines during the climb
2. Relevant
I've only been doing this for 3 weeks now, and i get some of it
but don't get most.
anyhelp would be nice..., i get that there's alot.
but I am sure its basic stuff, I am not looking for answers
just help.
My attempt
a) tan = Vx/Vy
=139/241
=0.5767
=30 degrees
just a tidbit, i know that tan(29.96 =0.5767 But how do i get 0.5767 to = 29.96?)
b) V²=Vy²+Vx²
=241²+139²
=77402
=278.2121 m/s
The answers said it = 27.8m/s, why?
the next three are where i
have even less of an idea.
c) KE=½mv² right
=0.5x3000x278.2121
=417318.15j, but that's too high,right?
the answer book said it =1.16x108j , which
freaked me out because what is with the
x? where did that come from!
d) is it to do with PE=mgh? cause i did that, but no go
e) righteo.
(sorry for any spelling errors)
(B) the speed
2. Relevant
but don't get most.
just help.
My attempt
a) tan = Vx/Vy
=139/241
=0.5767 (just a tidbit, i know that tan(29.96 =0.5767
=30 degrees But how do i get 0.5767 to = 29.96?)
You have \tan\theta=0.5967 \Rightarrow \theta=\tan^{-1}(0.5967)
b) tan [/color]= V²=Vy²+Vx² The answers said
=241²+139² it = 27.8m/s, why? [/color]
=77402
=278.2121 m/s
I don't know you've got the tan there. The correct equation is V2=Vy2+Vx2. Hence, V2=77402, and thus V=√(77402)
Incidentally, is the bit I've highlighted in blue a typo, and should read 278?
c) KE=½mv² right
=0.5x3000x278.2121 so to me its goto be
=417318.15j, but that's too high?
Why do you think that? It is incorrect though, since you used the value for v instead of the value for v2
This means T=1.16x108=116000000
d)is it to do with PE=mgh?
Yes.
e) righteo.
Oh, the tan was a mistake
& I am a goob, i didn't get that T=1.16x108=116000000
stuff makes more sense, cheers.
38K
10K
9K
