Projectile Motion Distance Calculation
The discussion focuses on calculating projectile motion distance with constant velocity. It emphasizes defining initial positions, x0 and y0, as zero to facilitate solving for distance. Participants suggest that the next step is to calculate the x and y positions at a specific time of 2.9 seconds. The conversation indicates a collaborative approach to solving the problem. Overall, the thread provides guidance on applying basic physics principles to projectile motion calculations.
chelsea01
A projectile is launched at ground level with an initial speed of 46.0 m/s at an angle of 25.0° above the horizontal. It strikes a target above the ground 2.90 seconds later. What are the x and y distances from where the projectile was launched to where it lands?
Horizontal Motion(ax = 0)
x = x0 + Vx t
Vx = V0x = Vx = velocity is a constant.
Vertical Motion(assuming positive is up ay = −g = −9.80m/s squared)
y = y0 +1/2 (v0y + vy)t
vy = v0y − gt
(3.39)
y = y0 + v0yt −1/2gt2
This based on velocity being constant. Define x0 and y0 to be zero and solve for the desired quantities.
Welcome to the PF. :smile:
Looks good so far. You should be able to solve for x and y at time = 2.9s now...
  • · Replies 18 ·
