Projectile Motion - Hitting an edge
4 replies · 2K views
Mcoroklo
I've made a picture of the situation:
http://img11.imageshack.us/img11/7177/drawing1m.jpg
I need to find the expression for the start velocity v0. The ball should exactly hit the corner.
The function should have the distance L (Which both is x-distance and y-distance to the point) and the angle a as variables.
We can ignore air resistance.
Normal projectile motion equations:
x=(v0*cos(a)*t
y=(v0*sin(a)*t-1/2*g*t^2)
vx=v0*cos(a)
vy=v0*sin(a)-gt
I've been sitting with he assignment for 2 hours - trying both creative and stupid solutions!
First attempt was setting x=L and y=L and find the expression for v0.
I've also trying to set the v=0, but afterwards finding out the ball speed doesn't have to be zero.
Nothing has worked out so far.
Any suggestions?
Thanks a lot.
Might try this approach...
How far below the corner would the projectile strike if you aimed directly at the corner?
Hi Mcoroklo, welcome to PF>
Your two starting equations are correct. Use the first equation to eliminate time in the second. That should give you what you need.
... Thanks a lot!
I guess you guys know the feeling. A lot of time spend on outrageous thoughts, afterwards finding the solution is way simpler.
I actually had your solution to Kuruman, checked for input (40deg and 10m). It gave complex numbers and I tried another approach. Ofcourse it should give complex numbers for each angle outside the span of 45-90..
Thanks a lot to both of you.
Looking forward to participate in the forum, hopefully helping people to! :-)
Mcoroklo said:
... Thanks a lot!
Actually I read the problem wrong initially, I thought you were trying to solve for the angle given an initial velocity. But, if it helped, I am happy. The other posters approach is easier, my proposal was a conceptual way that might help with other similar problems. And it may have helped eliminate unecessary stuff if you were guessing and checking with numbers.
