Projectile Motion - Hitting an edge
The discussion focuses on finding the initial velocity (v0) needed for a projectile to hit a corner, given the distance (L) and angle (a). Participants suggest using the standard projectile motion equations to eliminate time and derive the expression for v0. One user shares their initial confusion about the problem and acknowledges the complexity of solutions outside a specific angle range. The conversation highlights the common experience of overthinking problems before realizing simpler solutions exist. Overall, the thread emphasizes collaboration and problem-solving in physics.
Mcoroklo
I've made a picture of the situation:
http://img11.imageshack.us/img11/7177/drawing1m.jpg
I need to find the expression for the start velocity v0. The ball should exactly hit the corner.
The function should have the distance L (Which both is x-distance and y-distance to the point) and the angle a as variables.
We can ignore air resistance.
Normal projectile motion equations:
x=(v0*cos(a)*t
y=(v0*sin(a)*t-1/2*g*t^2)
vx=v0*cos(a)
vy=v0*sin(a)-gt
I've been sitting with he assignment for 2 hours - trying both creative and stupid solutions!
First attempt was setting x=L and y=L and find the expression for v0.
I've also trying to set the v=0, but afterwards finding out the ball speed doesn't have to be zero.
Nothing has worked out so far.
Any suggestions?
Thanks alot.
Might try this approach...
How far below the corner would the projectile strike if you aimed directly at the corner?
Hi Mcoroklo, welcome to PF>
Your two starting equations are correct. Use the first equation to eliminate time in the second. That should give you what you need.
... Thanks a lot!
I guess you guys know the feeling. A lot of time spend on outrageous thoughts, afterwards finding the solution is way simpler.
I actually had your solution to Kuruman, checked for input (40deg and 10m). It gave complex numbers and I tried another approach. Ofcourse it should give complex numbers for each angle outside the span of 45-90..
Thanks a lot to both of you.
Looking forward to participate in the forum, hopefully helping people to! :-)
Mcoroklo said:
... Thanks a lot!
Actually I read the problem wrong initially, I thought you were trying to solve for the angle given an initial velocity. But, if it helped, I am happy. The other posters approach is easier, my proposal was a conceptual way that might help with other similar problems. And it may have helped eliminate unecessary stuff if you were guessing and checking with numbers.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
