Projectile Motion in 3D space (Writing an Aimbot)
wolfknight
Alright, so, I am writing an aimbot for a popular game, and I need a bit of help with calculating the correct pitch angle for the player. The weapon is a bow, so the arrows are affected by gravity. I am trying to find the pitch angle that accounts for gravity and distance from the Entity you are firing at.
My current code doesn't work, but I will post it anyways. I have researched the correct algorithm (I found it at http://en.wikipedia.org/wiki/Trajectory_of_a_projectile#Angle_required_to_hit_coordinate_.28x.2Cy.29) and have attempted to implement it. However, when the aimbot is being used, for some reason, it stays in the middle of my screen, regardless of the entity's Y value or the player's Y value. I have the velocity correct, and the gravity constant correct, and that is all I know.
Anyways, enough rambling, here is my code:
Code:
	private float getBowPitchFromEntity(Entity e) {
		double x = getX(e);
		double y = getY(e);
		double z = getZ(e);
		double velocity = getVelocity();
		double posX = Math.pow(x, 2) + Math.pow(z, 2);
		double height = y - getY(getPlayer());
		return (float)getTrajectory(posX, z, velocity, height);
	private double getTrajectory(double x, double z, double velocity, double height) {
		double vsquared = Math.pow(velocity, 2);
		double vquad = Math.pow(velocity, 4);
		double gxsquared = Math.pow(x * gravityConstant, 2);
		double gx = x * gravityConstant;
		double twoyvsquared = 2 * Math.pow(height * velocity, 2);
		double add = Math.atan2(vsquared + Math.sqrt(vquad - (gravityConstant * (gxsquared + twoyvsquared))), gx);
		double sub = Math.atan2(vsquared - Math.sqrt(vquad - (gravityConstant * (gxsquared + twoyvsquared))), gx);
		return Math.min(add, sub);
The gravity constant is -0.05D, and the velocity doesn't matter, as I have compared it to the in-game arrow velocity and it matches.
If anyone can help, I would appreciate it.
could you have a degrees vs radians issue? I noticed the last eqns using Math.atan2()
I also noticed that the wiki eqn says g*x^2 but you've used (g*x)^2 for gxsquared
Lastly, z doesn't appear to be used in the second function.
That might possibly be my problem. I got mad and deleted the module last night, so I'll rewrite it and try again. Thank you very much for your help!
Note to self: Never get mad at code and delete it instead comment it out in a more gentle deprecational mode.
