Projectile Motion in an Electric field
The problem involves projectile motion of protons projected into a uniform electric field, requiring the determination of two projection angles that allow the protons to hit a target at a specified horizontal distance. The context includes concepts from kinematics and electric forces.
  • Participants discuss the relationship between the angles of projection and the resulting trajectories, exploring the mathematical identities related to sine and cosine. There are attempts to derive the second angle based on the properties of the inverse sine function. Some participants suggest using the mass and charge of the proton in the equations to find acceleration and time of flight.
The discussion is active, with various approaches being explored to find the second angle of projection. Some participants have provided guidance on using specific equations and identities, while others are questioning the reasoning behind certain mathematical transformations and assumptions.
Participants note the significance of the optimal angle of 45 degrees in projectile motion and discuss the implications of different trajectories hitting the same target. There is an emphasis on understanding the relationship between the angles and the effects of gravity and electric fields on the motion of the protons.
Elvis 123456789
Protons are projected with an initial speed of v0 = 10^5 m/s into a region in which a uniform electric field E = 800N/C [down] is present. The protons are to hit a target that lies a horizontal distance of 10.0 mm from the point at which the protons are launched. a) find the two projection angles theta that will result in a hit b) what is the total duration of flight for each of the two trajectories?
(1) x = v0 cos (theta) t
(2) y = v0 sin (theta) t - 1/2at^2
F=qE=ma
a=(qE)/m
x = v0 cos(theta) t y = v0 sin(theta) t - 1/2 a t^2
when the proton hits its mark at 10 mm, the y displacement will be zero
1/2*a*t = v0 sin(theta) ===> t = (2*v0 sin(theta))/a
plugging t into the formula for the x displacement gives
x = v0 cos(theta)*(2*v0 sin(theta))/a
=> x = [(v0)^2 * sin(2theta)]/a
=> theta = 0.5 *arcsin( (a*x)/(v0)^2)
=> theta = 2.2 degrees
=> t = 10^-7 s
Now I don't really know how I am supposed to get the second angle
2*cos(theta)*sin(theta) = sin(2*theta). So if 2*theta can be above pi/2, there's a second solution, since the inverse sine function is double valued.
I don't really know what you mean by "if 2*theta can be above pi/2"
Try using the mass and charge of a proton in your equations. You need to use
[tex]qE = F[/tex]
Then break it up to
[tex]qE = ma[/tex]
[tex]\frac{qE}m = a[/tex]
First solve for the time of the vertical component.
[tex]y = v_0t + \frac{1}{2}at^2[/tex]
[tex]0 = v_0sin\theta t + \frac{1}{2}at^2[/tex]
[tex]-v_0sin\theta t = \frac{1}{2}at^2[/tex]
[tex]t = \frac{-v_0sin\theta}{\frac{1}{2}a}[/tex]
Then substitute time into horizontal component.
[tex]x = v_0t[/tex]
[tex]x = \frac{v_0cos\theta (-v_0sin\theta)}{\frac{1}{2}a}[/tex]
[tex]x = \frac{v_0cos\theta (2v_0sin\theta)}{-a}[/tex]
[tex]x = \frac{v_0^2 sin2\theta}{-a}[/tex]
[tex]\frac{-ax}{v_0^2} = sin2\theta[/tex]
Substitute
[tex]\frac{qEx}{mv_0^2} = 2sin\theta[/tex]
Solve for angle which will be your first angle, and then subtract it from 90 to get your other angle. Then I believe you can get time no problem.
[tex]qE = F[/tex]
Then break it up to
[tex]qE = ma[/tex]
[tex]x = v_0t[/tex]
Substitute
Why does subtracting the original angle from 90 degrees give me the other correct angle?
It surrounds the optimal angle of 45 degrees. They will hit the same spot, 10mm away. One will hit the spot because it'll be low to the ground and gravity will accelerate it downwards fast, while the other one will hit the spot because of the short wavelength of the parabola which equals a short distance across the x-axis even though the amplitude/height is larger.
I suppose that makes sense intuitively, but how can I prove that the other angle must be 90 minus the original angle in a mathematical way?
It's pretty much just like taking the vertical component and rotating the page around to make it the horizontal component, or in other words from sine to cosine.
Your original solution seemed fine, but you did not solve for theta. To do so, use the identity I gave. Then solve for theta using an inverse sine function. But the inverse sine function has two angles that will give the same result, one theta is below pi/4 (which is 45 degrees if you are not using radians), the other above pi/4.
  • · Replies 29 ·
10K
  • · Replies 24 ·
