Projectile motion of a fired gun
The discussion revolves around a projectile motion problem involving a gun firing horizontally from a height of 99.0 m with an initial speed of 250 m/s. Participants explore the time the projectile remains in the air, the horizontal distance traveled, and the vertical component of velocity upon impact.
  • Participants discuss the calculations for time in the air and horizontal distance, with some questioning the interpretation of the vertical component of velocity. There is also a separate discussion about comparing projectile motion on Earth and the Moon, focusing on the implications of different gravitational forces.
The discussion includes attempts to clarify the meaning of "vertical component of velocity" and whether it refers to magnitude or composite velocity. Some participants express doubts about the wording of questions and the assumptions behind them, while others provide insights into the relationships between horizontal and vertical components of motion.
Participants note the potential for confusion due to the phrasing of questions and the implications of gravity on projectile motion in different environments.
1MileCrash
A projectile is fired horizontally from a gun that is 99.0 m above flat ground, emerging from the gun at a speed of 250 m/s
how long is it in the air?
how far does it travel horizontally?
vertical component of velocity as it strikes the ground?
To find how long it is in the air for, I built a y position function:
y = 99 + -4.9t^2
And solved for when y = 0 to get a t of 4.49 seconds.
To find how far it traveled horizontally, I built an x position function:
x = 250t
And solved for when t = 4.49 seconds to get 1122.5 meters traveled horizontally.
For the vertical component of velocity as it strikes the ground, I simply differentiated my y position formula and solved for t = 4.49 seconds, but this is incorrect. I'm not sure I fully understand what the "vertical component of velocity" is.
Thanks.
So, why do you say it's incorrect? What answer did you get for that part and what "correct" answer are you comparing it to?
The vertical component is your y component, just like you thought.
Sorry, my first two answers are correct. My last is incorrect, which is -44.
EDIT: It just needed to be positive, it's a magnitude.
Not worth making a new topic over:
Identical guns fire identical bullets horizontally at the same speed from the same height above level planes, one on the Earth and one on the Moon. Which of the following three statements is/are true?
The horizontal distance covered on the moon is greater
The flight time is less for the bullet on earth
The velocity is same at the point of impact
First two?
First two?
If you understand the concepts, then you should have no doubts about your answer. Do you have any doubts about the true/false nature of a specific statement?
I have doubts that they are talking about the magnitude of the velocity vector vs horizontal component alone in the last.
I read "velocity at point of impact" as the composite velocity.
Yes, it's asking about a composite velocity, but if you break down the components it becomes quite simple. If you can answer the following two questions without doing the math, then you understand the concepts. If not, then do the math and it should become clear.
How do the x component velocities compare (is one larger or are they equivalent)?
How do the y component velocities compare?
Of course it is quite clear assuming on or the other is the question intent. Same horizontal, different vertical, therefore different total.
First two?
Just think of how the different gravities affect the bullets and other forces such as friction in the air and your answer should be quite simple to come to.
Again, my doubt lies within the way the question is worded.
It is natural to have doubt's based on exposure to poorly-worded questions, typos, omissions, bad translations, etc.
But in this case, the question is not poorly worded. "velocity" simply means composite velocity. If you look back at the OP question, they took the time to explicitly write "vertical component of velocity" when they meant vertical component of velocity.
If you still have a doubt, answer the question, but stipulate your interpretation of the word "velocity" and answer appropriately.
Best regards.
My two questions were for conception/understanding. They weren't actually in reference to solving the original question. Answering those two questions helps to highlight the differences.
It is quite clear that the 2nd original question ("which of these is true") is asking for the actual velocity of the projectile(s), not simply one or another component.
Alright, thanks guys.
