Projectile Motion: How Far Will a Seed Travel at a Given Angle and Velocity?
To determine how far a seed travels when ejected from a height of 1.4 m at a velocity of 3.0 m/s at a 20-degree angle below the horizontal, the velocity must be broken into x and y components. The x-component is calculated as 3cos(20), while the y-component is 3sin(20). The quadratic equation is used to find the time of flight, with the equation set up as 0 = 1/2(9.8)t^2 + 3sin(20)t + 1.4. The total horizontal distance can then be calculated by multiplying the x-component by the overall time. This approach provides a systematic method to solve the projectile motion problem.
runningirl
You spit a seed from a height of 1.4 m above the ground, at a velocity of 3.0 m/s at an angle of 20 below the horizontal. How far from you does it land?
vxo= vo(cos20)
vyo=vo(sin20
not sure where to start..
Break the overall velocity into x and y components.
x direction <=> 3cos(20) = ?
y direction <=> 3sin(20) = ?
Use quadratic equation to find the overall time.
0= 1/2 (9.8)t^2 ( value for a) + 3sin(20)t (value for b) + 1.4 (value for c)
Total distance traveled can be calculated by ( 3cos(20) x ( overall time))
P.S. Next time , at least try to initiate the attempt.
Good luck.
  • · Replies 39 ·
