Projectile Motion range equation
12 replies · 3K views
Kingyou123
Uploaded
x(t)=xo+v0xT+1/2axt^2
(2Vo)costheta(t)=R, How would I get rid of T?
Kingyou123 said:
Uploaded
Can you show how you arrived at your solution attempt? What does "costheta(t)" represent?
Velocity Intial of x is equal to vocostheta, should I be using range =(vo^2sin2(theta))/gravity. I'm really lost right now...
Okay, that's a bit better. The Range equation is a good approach. You should place the entire argument of a function within the parentheses to make it clear what the function argument is. Thus:
R = (vo2/g) sin(2θ)
(Note that you can use the ##x_2## and ##x^2## icons in the edit panel header to invoke superscripts and subscripts, and greek letters and other symbols can be selected from the ##\Sigma## icon's menu)
The range equation gives you the range of a projectile that's launched with a given velocity ##v_o## at a given angle ##\theta##. So what happens to the range if you double the launch velocity?
For the second part of the question, take a browse though your table of trig identities then ponder what happens to sin and cos if the angle is adjusted as specified in the question.
R = (vo2/g) sin(2θ)
Would it be 2R since the velocity is doubled?
Can you justify that with an argument based upon the range equation? I won't confirm or deny a guess...
I plugged 10 for the in initial velocity so doubling that would make 20/g therefore the outcome would be twice as great. Right logic or I'm I completely off/
It is not correct. Does the range equation use ##v_o## or ##v_o^2##? How does squaring a doubled value affect the net result?
ohhhhhhh would it be 4R cause by doubling 1 you get 2 and 2^2 is 4 so in this case quadruplicating the R.
Bingo! It always pays to consider the equation involved and not rely on instinct alone :smile:
Thank you so much it makes so much more sense now :) Would you be up to help with the rest of homework when I get stuck?
For the second part would the angle be greater causing the distance to decrease? If I plug 30 in for theta, sin(90-30), the angle is greater than the previous 30, but if I plug 85 for theta the answer would less than...
