Projectile motion with unknown angle and Vo
15 replies · 8K views
Femme_physics
http://img854.imageshack.us/img854/6055/footballer01.jpg
A footballer kicks a ball and therefor the ball arrives at point C, above the goal at 4 meters height
Presuming that point C is at max height of the path and distance AB is 20 meters, calculate the speed of the ball (Va - angle and magnitude) during the kick. Presume that the ball is a material point.
I'm getting stuck. I'm not sure whether it's my issue with solving trigonometric equations, or have I not applied the correct method? This is the first time I find a projectile motion problem to be so tough!
http://img8.imageshack.us/img8/962/footballer02.jpg
You're mixing up your symbols.
In equation #2 you're using v0, while this should be vy.
That should make it (quite a bit) easier. ;)
EDIT: Btw, where did you get equation #4 from?
Hmm. I'll try it now then.
Geez...what a tough problem!
This?
http://img852.imageshack.us/img852/3820/thisr.jpg
Uploaded with ImageShack.us
Our lecturer gave it to us. He seemed to be holding it as a really special great formula!
The movement of the ball can be split in two indipendent components: one vertical and one horizontal.
Then you can mix them up in the end.
In addition you may know that almost every law is reversible in time: that means you can imagine someone throwing a ball at the top of the 4 meters pole and the ball has to reach the player.
I don't appear to have a need for time. Adding time into the equations seem like extra work!
From what you're saying though, it appears that I'm making my life harder using the trajectory formula. Can I simply use the formulas of
http://img802.imageshack.us/img802/8066/3components.jpg
Wait, ignore that last equation. It should be V2=Vx2+Vy2
Femme_physics said:
This?
Ah, I see.
I think it should be:
[tex]g \cdot h = \frac {v_0^2 \cdot \sin^2 \alpha} 2[/tex]
That should give you the answer as well.
Just to keep tab, I got 3 unknowns (angle, vox and voy) and I can use 5 equations to try and solve it?
*also, I'm surprised he confused the formula! Or maybe I mis-copied it? Hmm...
Ok, and how much time take for an object to fall from an height H under the acceleration of gravity g ?
I just realized I accidentally added "time" into the equation
Hmm, those other formulas are not quite right either.
It should be:
[tex]v_x=v_0 \cos \alpha[/tex]
[tex]v_y=v_0 \sin \alpha - g \cdot t[/tex]or
[tex]v_{0x}=v_0 \cos \alpha[/tex]
[tex]v_{0y}=v_0 \sin \alpha[/tex]
Actually you have a 4th unknown: v0.
And yes, you can try and solve it.
I can also suggest another approach.
Split the initial velocity in a horizontal and a vertical component, and set up the equations for the horizontal and vertical distance and speed.
Up to you though.
Before you were able to state that the ball takes 0.903 sec to reach the top.
At the top you also know the ball doesn't rise further, so Vy must be... ?
You know g, t, Vy when the ball is at the top, get a value for [tex]V_0 \ sin (\alpha)[/tex]
using your equations.
