How can the inequality cosx ≥ (1-x^2/2) be proven?
The inequality cos(x) ≥ (1 - x^2/2) can be proven by analyzing the function g(x) = cos(x) - 1 + (x^2/2) over the interval [-2, 2]. For values of x outside this interval, 1 - x^2/2 is less than -1, which is always less than the minimum value of cos(x). The discussion emphasizes the importance of evaluating the first and second derivatives of g(x) to find its minimum within the specified domain, confirming that the inequality holds for all real numbers.
  • Understanding of trigonometric functions, specifically cos(x)
  • Familiarity with calculus concepts such as derivatives and critical points
  • Knowledge of inequalities and their properties
  • Ability to analyze functions graphically
  • Study the behavior of g(x) = cos(x) - 1 + (x^2/2) and its derivatives
  • Learn about the properties of continuous functions on closed intervals
  • Explore the implications of Taylor series in approximating cos(x)
  • Investigate the relationship between integrals and function positivity
Mathematicians, calculus students, and educators seeking to deepen their understanding of inequalities involving trigonometric functions and their proofs.
mech-eng
Proof of the inequality ##cosx \ge (1-x^2/2##
##1\ge cosx \ge 0##
How can the inequality ##cosx \ge(1-x^2/2)## be proved? Would you please explain how to prove this inequality?
This is the only equation that I could think of. ##1\ge cosx \ge 0## but I cannot use it here.
Source: Thomas's Calculus, this is from an integration question there.
Thank you.
Thank you.
PF rules require an effort on your part.
I know it intuitively but I cannot establish a good way. I cannot express it in a good form. For less than -2, ##1-x^2/2## is less than -1 so this is valid. For more than 2, ##1-x^2/2## is less than -1 this is also valid. Between -1 and 1, ##1-x^2/2## is between 1/2 and 1 and the equation is also valid.
Thank you.
Since the question is in a section about integration, one approach would be to look at the graph of ##y = \cos(x) - 1 + \frac {x^2} 2##, and see if the integral of this function is positive or negative.
What does the integral have to do with whether or not the function itself is positive, which is what is relevant to this question?
If the integral is positive on some interval where cos(x) and 1 - x^2/2 don't intersect, it means that cos(x) >= 1 - x^2/2. That was my thinking. The OP mentioned that the problem was in a section on integration, which I presume comes in a section before Taylor's series are covered.
Thank you.
I see the ingredients of a solution sitting here though we are guessing a bit since we don't know the background... I assume 1st and 2nd derivatives are ok at this point.
I found "##1\ge \cos x \ge 0##" interesting because when I set ##x := \pi##
I get something that violates this. You are right that the magnitude of cosine of x is bounded in 0 and 1.
Yes -- so why not use this fact to truncate your domain to ##x \in [-2,2]##.
Note this interval is closed and bounded (compact in reals) and thus any continuous function has a minimum in this interval. So check for values of the function ##g(x)## the border at ##x=-2## and ##x=2## and also use 1st (and 2nd) derivatives to find the minimum value of the function ##g##... I'd suggest using the one that Mark gave, i.e.
##g(x) = \cos(x) - 1 + \frac {x^2} 2## again for ##x \in [-2,2]##
StoneTemplePython said:
Yes -- so why not use this fact to truncate your domain to x∈[−2,2]x∈[−2,2]x \in [-2,2]
Yes, for the domain [-2,2] this is valid but in the original question it is said that this is valid for all real number which means the domain is [##-\infty, \infty##]. So this is confusing.
ok, let's be clear -- the original domain is ##(-\infty, \infty)## that's an open interval that doesn't actually include +/- ##\infty##
Second, let's partition that into 3 pieces -- i.e.
##(-\infty, \infty) = (-\infty, -2) \cup [-2, 2] \cup (2, \infty)##
so we have 3 different pieces to consider:
##\{(-\infty, -2) , [-2, 2], (2, \infty)\} ##
for ##(-\infty, -2)## and for ## (2, \infty)##
apply this argument
The argument needs cleaned up a little bit but it is a key insight.
what remains is to consider the case of ##x \in [-2,2]## which was what I was pushing you to focus on in post 7.
Okay. Thank you. I got it. For all x beyond the interval [-2,2] ##1-x^2/2## is less than -1 which is also less than the minumum of cos x for all x.
  • · Replies 18 ·
