Proof of Addition Reversibility
In summary, the conversation discusses how to prove that ##f(x)=g(x)## if and only if ##f(x)+C=g(x)+C##, and the role of groups in this proof. It also discusses the reversibility of operations that do not belong to groups, such as exponentiation.
FAS1998
50
How can you prove that
##f(x)=g(x) \Leftrightarrow f(x)+C=g(x)+C##
Mathematics news on Phys.org
I can't as long as I don't know where your elements are taken from.
Likes FAS1998
What do you mean by "elements"?
##f(x),g(x),C##
If they were, as usual, from ##\mathbb{R}##, then the answer would be: because ##(\mathbb{R},+)## is a group. But if you had defined addition differently on some set, then there is not enough information about it.
E.g. ##1+1=2## and ##1+1=0## are both true, just not in the same set.
Likes FAS1998
fresh_42 said:
##f(x),g(x),C##
This is what I meant.
I just looked over the wikipedia page for groups and now understand why ##(\mathbb{R},+)## is a group, but why does belonging to a group imply reversibility?
Being in a group means existence of an additive inverse, -C.
So given that ##f(x)+C=g(x)+C## you can write down ##f(x)+C+ -C=g(x)+C+ -C##.
Given associativity, the definition of an additive inverse and the definition of zero, it is all downhill from there.
Likes FAS1998
How would we prove the reversibility of other operations such as exponentiation (for values >= 0), that don't belong to groups?
##x \longmapsto e^x## or ##x \longmapsto x^n## e.g. by the theorem of invertible functions or in general step by step. They aren't operations anymore, just other functions.
Likes FAS1998
1. What is "Proof of Addition Reversibility"?
"Proof of Addition Reversibility" is a mathematical concept that states that if two numbers are added together, the result can be reversed by subtracting one of the numbers from the sum.
2. Why is "Proof of Addition Reversibility" important?
"Proof of Addition Reversibility" is important because it is a fundamental property of addition that allows us to check our calculations for accuracy. It also helps us understand the relationship between addition and subtraction.
3. How is "Proof of Addition Reversibility" demonstrated?
"Proof of Addition Reversibility" can be demonstrated by using a simple example, such as 3 + 5 = 8. This can be reversed by subtracting 3 from 8, giving us 8 - 3 = 5, which is the other original number in the addition equation.
4. Does "Proof of Addition Reversibility" apply to all numbers?
Yes, "Proof of Addition Reversibility" applies to all numbers, including whole numbers, fractions, and decimals. As long as the two numbers being added together are real numbers, the result can be reversed by subtraction.
5. How is "Proof of Addition Reversibility" used in real life?
"Proof of Addition Reversibility" is used in everyday life, such as when balancing a checkbook or calculating change when making a purchase. It is also used in more complex mathematical concepts, such as algebra and calculus.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
