Proof of EM Wave Orthogonality: Ideas Needed
  • Context: Graduate
  • Thread starter Thread starter dave4000
    Em Em wave Wave
The discussion revolves around the proof of the orthogonality of the electric field (E), magnetic field (B), and the direction of propagation (k) in electromagnetic waves. Participants explore mathematical relationships and physical interpretations related to this concept, including the use of plane waves and spherical wavefronts.
  • Some participants present equations for E and B fields and express difficulty in deriving the relationships that demonstrate their orthogonality.
  • One participant suggests taking the dot product as a potential method to clarify the relationships between the fields.
  • Another participant introduces the Poynting vector, explaining its significance in representing the direction and magnitude of power flow, noting that both E and H are orthogonal to this direction.
  • There is a discussion about the distinction between spherical and plane waves, with some arguing that plane waves simplify the mathematics involved.
  • One participant confirms that they have resolved their issues with derivatives after reviewing previous responses.
  • A question is raised about the relationship between the wavenumber (k) and the direction of propagation, with clarification provided that k is a scalar while \vec{k} is a vector indicating direction.
Participants express varying levels of understanding regarding the mathematical proofs and relationships involved. While some agree on the orthogonality of the fields, the discussion remains unresolved regarding the best approach to derive these relationships and the implications of different wave types.
Participants note that the complexity of the mathematics may depend on whether spherical or plane waves are used, indicating that assumptions about wave type can influence the discussion.
dave4000
So I am trying to work through the proof why why the direction of proporgation, the E field and B field are all orthogonal to one another.
What i have is...
[tex]E=E_{0}e^{i(k\ \bullet \ r-\omega t)}[/tex]
[tex]B=B_{0}e^{i(k\ \bullet \ r-\omega t)}[/tex]
[tex]\nabla \times E= -\frac{dB}{dt} \Rightarrow k \times E_{0}= \omega B_{0}[/tex]
[tex]\nabla \times B= \mu_{0}\epsilon_{0}\frac{dE}{dt} \Rightarrow k \times B_{0}= \mu_{0}\epsilon_{0}\omega E_{0}[/tex]
and i can see from this why k, B and E must be orthogonal. What I am having difficulty with is how to get from the left to the right...
Any ideas?
Any ideas?
It is interesting and very useful to think about two signals passing one another in a coax cable (e.g., RG-8) without interference. I show cartesian coordinates below, but in a coax, E is radial, and H is azimuthal. Also, for RG-8, E/H = 50 ohms
Ex = E0 exp[j(k z - w t)]
Hy = H0 exp[j(k z - w t)]
and
Ex = E0 exp[j(-k z - w t)]
Hy = -H0 exp[j(-k z - w t)]
So one pulse goes from left to right, and the other from right to left, without a "collision". There are instruments (directional couplers) that can measure the amplitude AND direction of each pulse simultaneously.
Edit: changed k x to k z four places
You mean how to work out the derivatives?
What i have is...
<snip>
Any ideas?
Have you tried taking a dot product?
Edit- I just noticed the form you wrote for E and B- spherical wavefronts. That can complicate the maths, so it's easier to use plane waves.
For a plane wave, we can use the vector identity (ignoring any currents J)
div(E x H) = H curl E - E curl H
= -E dD/dt - H dB/dt = -1/2 (d/dt)(e0E2 + u0 H2). (= energy loss per meter). So
S= E x H is a vector (called the Poynting vector), whose direction is the direction, and magnitude is the average power flow, in watts per square meter. Both E and H are orthogonal to direction of power flow.
Actually, the OP is using plane waves (and just not specifying the direction of propagation in Cartesian coords, explicitly). Spherical waves have a much more complicated form.
What i have is...
Any ideas?
If you are having trouble working out the derivatives, it will help you to look at my responses to question 2. in this thread since you are essentially both trying to work out the same curls...Are you also having trouble with the time derivatives?
That thread has proved helpful - i have cracked the derivatives. Thanks.
Another question though, k is the wavenumber right? Is the wavenumber equivalent to the direction of proporgation?
I mean, from the solution k, E and B must be orthogonal, but how does this relate to the direction of proporgtaion?
You're welcome!:smile:
The scalar [itex]k[/itex] is the wavenumber, the vector [itex]\vec{k}[/itex] which appears in your plane waves (it's a good idea to get into the habit of explicitly writing vectors with some sort of marking to distinguish them from scalars!) , is defined as the product of the wavenumber with the unit vector in the direction of propagation. In other words, [itex]\vec{k}[/itex] points in the direction of propagation and its magnitude is the wavenumber.
  • · Replies 36 ·
  • · Replies 39 ·
  • · Replies 17 ·
