Proof of multiplicative inverse of complex number
The discussion focuses on deriving the formula for the multiplicative inverse of a complex number, represented as z = a + bi. The inverse is expressed as z-1 = u + vi, where the conditions (au - bv) = 1 and (av + bu) = 0 must be satisfied. The solution provided by a teacher is z-1 = a/(a2 + b2) - bi/(a2 + b2). Participants discuss methods to solve the system of equations, including matrix representation and substitution techniques.
  • Understanding of complex numbers and their representation.
  • Familiarity with systems of linear equations.
  • Knowledge of matrix operations and row reduction techniques.
  • Basic algebraic manipulation skills.
  • Learn how to derive the multiplicative inverse of complex numbers using algebraic methods.
  • Study matrix representation of linear equations and row reduction techniques.
  • Explore the geometric interpretation of complex numbers and their inverses.
  • Investigate alternative methods for solving linear systems, such as substitution and elimination.
Students studying complex numbers, mathematics educators, and anyone interested in understanding the properties and operations involving complex numbers.
philnow
I'm trying to derive the formula for the multiplicative inverse of a complex number. I say that:
z=a+bi
z-1=u+vi
and zz-1 must be 1 so
zz-1=(a+bi)(u+vi)
=(au-bv)+(av+bu)i
=1
So in order for zz-1=1, (au-bv) must be 1 and (av+bu) must be 0. My teacher has solved this as:
z-1= a/(a2+b2) - bi/(a2+b2)
I just don't know how to get that from au-bv=1 and av+bu=0
2. The attempt at a solution
Don't know how to get the last part... major brain fog. Please help?
It's just a system of two linear equations in the two unknowns u and v. You can set it up as a matrix and do row reduction or you can do it the old fashioned way.
z=a+bi
z-1=u+vi
zz-1=(a+bi)(u+vi)
=(au-bv)+(av+bu)i
=1
I don't see that you have used the fact that z-1 = 1/(a + bi). Multiply the latter expression by 1 in the form of (a - bi)/(a - bi). See if that helps.
Thanks Mark, I got the answer using your method :)
But, if I were to solve this using linear algebra, what would my matrix look like? I think:
a -b 1
b a 0
That doesn't look right, and I'm having difficulties solving this. Any pointers? Thanks in advance.
a matrix is overkill for this one.
you have au - bv = 1 and av + bu = 0
so u = (1 + bv)/a. substitute this into the second one to getav + b\frac{(1 + bv)}{a} = 0
v(a + \frac{b^2}{a}) = -\frac{b}{a}
v\frac{a^2 + b^2}{a} = -\frac{b}{a}you can probably take it from there.
If you do want to do it with matrices, the first step is to multiply the first row by -b/a and add it to the second row. That should get you going.
You're a champ, thanks a lot!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
  • · Replies 19 ·
