Proofs about the second-order linear differential equation?
The discussion revolves around the second-order linear differential equation of the form ## \frac{d^2u}{dx^2}+\frac{fu}{2}=0 ##, where ## f=f(x) ##. Participants are exploring the implications of assuming solutions based on the nature of the function ## f ##, particularly in cases where it is non-constant.
  • Participants discuss the derivation of solutions ## u_1 ## and ## u_2 ##, questioning the validity of assuming a constant function for ## f ##. There are inquiries about the correctness of the characteristic equation and the implications of differentiating functions that depend on ## f(x) ##.
There is an ongoing examination of the assumptions made regarding the function ## f ##, with some participants suggesting that the original poster's approach may not hold for non-constant functions. Clarifications are being sought regarding specific parts of the problem and the nature of the solutions presented.
Participants note that the original poster's solutions may only be valid under the assumption that ## f ## is constant, and there is a recognition that differentiating functions dependent on ## f(x) ## requires careful application of the chain rule. The discussion is focused on understanding the implications of these assumptions without reaching a definitive conclusion.
Math100
Let ## u_{1} ## and ## u_{2} ## be two linearly independent solutions of the second-order linear differential equation ## \frac{d^2u}{dx^2}+\frac{fu}{2}=0, f=f(x) ##.
(i) Let ## w=u_{2}/u_{1} ##. Show that ## w'=c/u_{1}^2 ## for some nonzero constant ## c ##.
(ii) Let ## y=-2u_{1}'/u_{1} ##. Show that ## y ## satisfies the Ricatti equation ## y'-\frac{y^2}{2}=f ##.
(iii) Show that ## w''/w'=-2u_{1}'/u_{1} ##, and prove that ## w ## satisfies the equation ## (\frac{w''}{w'})'-\frac{1}{2}(\frac{w''}{w'})^2=f ##.
(iv) Hence find a general solution of the equation ## (\frac{w''}{w'})'-\frac{1}{2}(\frac{w''}{w'})^2=2 ##. [You are not required to prove that your answer is the general solution.]
None.
Proof:
(i) Consider the second-order linear differential equation ## \frac{d^2u}{dx^2}+\frac{fu}{2}=0, f=f(x) ##.
Then ## u''+\frac{f}{2}u=0\implies r^2+\frac{f}{2}=0 ##, so ## r=\pm \sqrt{\frac{f}{2}}i ##.
This implies ## u_{1}=c_{1}cos(\sqrt{\frac{f}{2}}x) ## and ## u_{2}=c_{2}sin(\sqrt{\frac{f}{2}}x) ##.
Note that ## u_{1}'=-\sqrt{\frac{f}{2}}c_{1}sin(\sqrt{\frac{f}{2}}x), u_{2}'=\sqrt{\frac{f}{2}}c_{2}cos(\sqrt{\frac{f}{2}}x) ##.
Let ## w=\frac{u_{2}}{u_{1}} ##.
Then ## w'=\frac{u_{1}u_{2}'-u_{2}u_{1}'}{u_{1}^2}=\frac{c}{u_{1}^2} ##.
Observe that ## w'=\frac{c_{1}cos(\sqrt{\frac{f}{2}}x)\cdot \sqrt{\frac{f}{2}}c_{2}cos(\sqrt{\frac{f}{2}}x)-c_{2}sin(\sqrt{\frac{f}{2}}x)[-\sqrt{\frac{f}{2}}c_{1}sin(\sqrt{\frac{f}{2}}x)]}{u_{1}^2}=\frac{c}{u_{1}^2} ##.
Thus ## w'=\frac{\sqrt{\frac{f}{2}}c_{1}c_{2}cos^2(\sqrt{\frac{f}{2}}x)+\sqrt{\frac{f}{2}}c_{1}c_{2}sin^2(\sqrt{\frac{f}{2}}x)}{u_{1}^2}=\frac{c}{u_{1}^2} ##,
so ## w'=\frac{\sqrt{\frac{f}{2}}c_{1}c_{2}}{u_{1}^2}=\frac{c}{u_{1}^2} ##, where ## c=\sqrt{\frac{f}{2}}c_{1}c_{2} ##.
Therefore, ## w'=c/u_{1}^2 ## for some nonzero constant ## c ##.
(ii) Let ## y=-\frac{2u_{1}'}{u_{1}} ##.
Then ## y'=\frac{u_{1}(-2u_{1}'')-(-2u_{1}')(u_{1}')}{u_{1}^2}=\frac{-2u_{1}u_{1}''+2(u_{1}')^2}{u_{1}^2} ##.
Consider the Ricatti equation ## y'-\frac{y^2}{2}=f ##.
Observe that ## \frac{-2u_{1}u_{1}''+2(u_{1}')^2}{u_{1}^2}-\frac{1}{2}(-\frac{2u_{1}'}{u_{1}})^2=f ##
## \frac{-2u_{1}u_{1}''+2(u_{1}')^2}{u_{1}^2}-\frac{1}{2}(\frac{4(u_{1}')^2}{u_{1}^2}=f ##
## \frac{-2u_{1}u_{1}''+2(u_{1}')^2-2(u_{1}')^2}{u_{1}^2}=f ##
## \frac{-2u_{1}u_{1}''}{u_{1}^2}=f ##.
Since ## y'-\frac{y^2}{2}=\frac{-2u_{1}u_{1}''}{u_{1}^2}=f ##, it follows that ## -2u_{1}u_{1}''=fu_{1}^2\implies -2u_{1}''=fu_{1}\implies u_{1}''=-\frac{fu_{1}}{2}\implies u_{1}''+\frac{fu_{1}}{2}=0 ##.
Therefore, ## y ## satisfies the Ricatti equation ## y'-\frac{y^2}{2}=f ##.
(iii) Let ## w'=\frac{c}{u_{1}^2} ## for some nonzero constant ## c ##.
Then ## w''=(cu_{1}^{-2})'=-2cu_{1}^{-3}u_{1}'=-\frac{2cu_{1}'}{u_{1}^3} ## by the chain rule.
Thus ## \frac{w''}{w'}=\frac{-2cu_{1}'}{u_{1}^3}\cdot \frac{u_{1}^2}{c}=\frac{-2u_{1}'}{u_{1}} ##.
Therefore, ## y=\frac{-2u_{1}'}{u_{1}}=\frac{w''}{w'} ## (by part ii) and ## w ## satisfies the equation ## (\frac{w''}{w'})'-\frac{1}{2}(\frac{w''}{w'})^2=f ##.
(iv) By parts (ii) and (iii), we have that ## y=\frac{w''}{w'}=\frac{-2u_{1}'}{u_{1}} ##.
Then ## (\frac{w''}{w'})'-\frac{1}{2}(\frac{w''}{w'})^2=2\implies y'-\frac{1}{2}y^2=2 ##.
Now we have ## \frac{dy}{dx}=2+\frac{y^2}{2} ##.
Observe that ## \frac{dy}{dx}=\frac{4+y^2}{2} ##
## \frac{dy}{4+y^2}=\frac{dx}{2} ##
## \int \frac{dy}{4+y^2}=\int \frac{dx}{2} ##
## \frac{1}{2}\cdot tan^{-1}(\frac{y}{2})=\frac{x}{2}+c ##
## tan^{-1}(\frac{y}{2})=x+c ##
## \frac{y}{2}=tan(x+c) ##
## y=2tan(x+c) ##.
Therefore, a general solution of the equation ## (\frac{w''}{w'})'-\frac{1}{2}(\frac{w''}{w'})^2=2 ## is ## y=2tan(x+c) ##.
I am assuming you are trying to find out whether your work is correct or not. If ##f(x)## is non-constant then your solution doesn't work. See why by substituting any non-constant function, x for example.
Are you talking about the general solution? To which part of the problem are you referring to?
At the very beginning, you say that ##u_1=c_1\cos(\sqrt{\frac{f}2}x)##. I was saying that this is true only when ##f## is constant.
Okay, I see that now. Then what's the error here? Is the characteristic equation wrong?
Your solutions ##u_1## and ##u_2## are generally incorrect. If ##f## is constant then you're fine.
I would write ##u_i =-\dfrac{2}{f}u_i''## so ##\omega =\dfrac{u_2}{u_1}=\dfrac{u_2''}{u_1''}## and start with both differentiations of ##\omega ## since you have to do this anyway.
My comments apply to part (i) only.
Math100 said:
Homework Statement: Let ## u_{1} ## and ## u_{2} ## be two linearly independent solutions of the second-order linear differential equation ## \frac{d^2u}{dx^2}+\frac{fu}{2}=0, f=f(x) ##.
<snip>
1) Since f is a function, you should write this explicitly as f(x). Not doing so possibly led to the error that @mathhabibi points out.
2) You apparently are assuming a solution of the form ##y = e^{rx}##. This is something that you should state.
The error pointed out by @mathhabibi is that both ##u_1(x)## and ##u_2(x)## are functions that involve f(x), when you differentiate them, you need to use the chain rule.
I noticed the issue. Since both of the functions ## u_{1}(x), u_{2}(x) ## were incorrect, then how should I solve this differential equation and find these correct functions?
I forgot the fact that ## f ## is a function, not a constant.
A week or two ago, I was trying to solve the first differential equation in your post, except that ##p=\frac f2##. According to Wolfram alpha, it is a Riccati differential equation, so it is probably unsolvable. If you find a solution to it, then get ready for fame.
  • Haha
I see where you got the ## -\frac{2}{f}u_{i}''=u_{i} ## from. But I don't understand why/how does ## w=\frac{u_{2}}{u_{1}}=\frac{u_{2}''}{u_{1}''} ##. And by starting both differentiations of ## \omega ##, do you mean to take up to second derivatives of ## \omega ##?
##\omega =u_2/u_1## is a definition, and ## -\frac{2}{f}u_{i}''=u_{i} ## is the fact that they solve the differential equation. I only substituted the two into the definition of ##\omega ##. Of course, it could be that ##f(x)=0## somewhere, but I think we should first tackle the problem generically and bother about exceptions later on. Differentiating ##\omega ## yields new equations in which we could substitute former ones.
I don't think that you should try to solve the equation, especially as we don't know anything about ##f(x).## And it is not explicitly required. You are only asked about certain behaviors of flows (solutions). You can solve differential equations if you encounter easy ones e.g. ## v''+v=0## or ##v=v'.##
The general route to the proof should be:
- use as many pieces of information as you have
- calculate everything you have to calculate anyway at the beginning (for later use)
- ignore exceptions like ##f(x)=0## and deal with them at the end
- ##\omega ## is the quotient of two solutions; use this to get rid of common factors like ##-2/f.##
- draw solutions if necessary
I'm a little stale in this area, but, have you considered using characteristic curves?
I'm working on this proof, almost done.
Yes, writing an article about the meaning of differential equations in general was a lot easier. :cool:
Okay, here's my revised proof on part (i).
Then ## u_{i}''+\frac{fu}{2}=0\implies u_{i}''=-\frac{f}{2}u ##, so ## -\frac{2}{f}u_{i}''=u_{i} ##.
Given that ## w=\frac{u_{2}}{u_{1}} ##, we have ## w'=\frac{u_{1}u_{2}'-u_{2}u_{1}'}{u_{1}^2} ##.
Since ## u_{1} ## and ## u_{2} ## are linearly independent, it follows that their Wronskian is nonzero.
Note that ## W=u_{1}u_{2}'-u_{2}u_{1}'\neq 0 ##.
This implies ## W'=(u_{1}u_{2}'-u_{2}u_{1}')'=u_{1}u_{2}''+u_{1}'u_{2}'-u_{2}u_{1}''-u_{2}'u_{1}'=u_{1}u_{2}''-u_{2}u_{1}'' ##.
Observe that ## W'=u_{1}u_{2}''-u_{2}u_{1}''=u_{1}(-\frac{1}{2}f\cdot u_{2})-u_{2}(-\frac{1}{2}f\cdot u_{1})=0 ##.
Thus, ## W=\frac{u_{2}}{u_{1}}=u_{1}u_{2}'-u_{2}u_{1}' ## is a nonzero constant ## c ##.
Therefore, ## w'=\frac{c}{u_{1}^2} ## for some nonzero constant ## c ##.
What are characteristic curves?
The line before the last should be
Thus, ## W=u_{1}u_{2}'-u_{2}u_{1}' ## is a nonzero constant ## c ##.
since it is only the numerator of ##\omega .##
  • Love
And also ## w ## instead of the Wronskian ## W ##.
And you didn't use a division by ##f(x)## so it should work in all cases where ##f(x)## has zeros, too!
Any Weak/Distributional solutions?
  • · Replies 18 ·
