Propelling A Small Rocket With Magnets?
  • Context: High School
  • Thread starter Thread starter NoobofPhysics
    Magnets Rocket
The discussion focuses on creating a magnetic launching system for a model rocket as part of a high school senior project. Participants suggest using an induction launcher and a capacitor bank to power electromagnets, emphasizing the importance of understanding capacitor configurations in series and parallel for optimal performance. Additionally, they discuss the potential use of a Faraday cage to protect electronics from electromagnetic interference. The conversation highlights various propulsion methods, including plasma rockets and the challenges of using powerful magnets in a school project.
  • Understanding of electromagnetism and magnetic propulsion
  • Knowledge of capacitor configurations in electronics
  • Familiarity with SolidWorks for 3D modeling
  • Basic principles of Faraday cages and electromagnetic interference
  • Research "induction launcher" and its applications in model rocketry
  • Study "capacitor bank design" for energy storage and release
  • Explore "Faraday cage construction" for protecting electronic components
  • Investigate "plasma propulsion systems" and their feasibility for small models
Students in physics or engineering, hobbyists interested in model rocketry, and anyone exploring electromagnetic propulsion systems.
NoobofPhysics
My senior project for high school is to prove that NASA can make their launch more efficient by adding electromagnets to launch. I was thinking just magnets lining a tunnel coming from underground that move the payload a lot like a maglev. My job is to make a model of this, and I'd like to make a real, working model.
I will print out a tiny model of a rocket that I design myself in Solidworks, but when it comes to launch I'm stuck. Does anyone have any suggestions on how I can make a small magnetic launching system for my model?
Thanks!
Google "induction launcher".
You'll probably need a small capacitor bank to power your magnets(presumably electromagnets). Basically, this is just a bunch of capacitors wired in series and parallel to store energy, and release it in a pulse, resulting in a higher amount of power at the same energy. Please note that because it is the same energy, the time is shortened, which is why it has the higher power.
The capacitors in series provide a higher voltage, which can push a larger current, but at the expense of capacitance. Just add the voltages of the capacitors together for the total voltage. The capacitance in series is given by C^-1 = c(1)^-1 + c(2)^-1 + c(3)^-1 and so on.
The capacitors in parallel provide an increase in capacitance and current flow. The capacitance of parallel is just to add the capacitance of the parallel capacitors. The current is the same, if the current is all converging to a single point. In this case, the current is added. This requires that the voltage be the same. However, this does NOT work if the voltage is NOT the same in all the branches.
You should probably get a basic electronics book at the library if you need more information.
If you need a place to buy some capacitors, you could try mouser.com. I bought a few pieces from them, and they literally have a crapload of stuff on the website.
In real life, how would you stop the magnet from messing with the electronics? It is going to have to be a pretty powerful magnet.
Thanks!
Arent they talking about how to launch the rocked itself, are they looking for a better way to load the rocked. But ofcourse, there are many ways to launch a rocket with electromagnetism. If the rocket is made out of iron, or is a one huge electromagnet, it can be propelled from the ground by magnets. Or it can also propell plasma gas and ionized gas with magnetic propulsion. Plasma rockets actually are probably going to be the next generation of rockets.
That's a fairly simple problem to solve. I believe a faraday cage is what is used to screen electric and some electromagnetic radiation(depending on the size of the holes used in the screen). Basically, it's just a metal cage with small holes.
How does that work then?
As I can see how it would block lightning and possibly average out an oscillating magnetic or electric field. However, if the magnet is turned on and stays on, as in this example, I don't see how it could work.
I had forgotten about that. In that case, I'm pretty sure magnetic permeability interferes with the magnetic field. I think it draws the magnetic field lines into it or something. Wikipedia also has something on the Meissner effect, but I doubt superconductors are going to be used in a school science fair.
Sounds like a scaled down gauss cannon or rail gun would be easier to make. Just make sure your rocket is non Ferris. But I don't know if that would count as a magnetic launch.
  • · Replies 28 ·
  • · Replies 42 ·
