Properties of cross and dot products
The discussion revolves around the properties of dot and cross products in vector algebra. The original poster presents a scenario involving a nonzero vector u and two vectors v and w, questioning whether the conditions u.v = u.w and u x v = u x w imply that v equals w.
  • Participants explore the implications of the dot and cross products, questioning the original poster's reasoning about the equality of vectors based on their scalar and vector products. There is a suggestion to use specific formulas related to the dot and cross products to clarify the argument.
The discussion includes various interpretations of the mathematical relationships involved. Some participants offer guidance on using formulas to strengthen arguments, while others challenge the clarity of the original reasoning. A participant asserts that the conclusion v = w is correct based on the conditions provided, but this assertion does not lead to a consensus.
Participants note the importance of understanding the geometric implications of the dot and cross products, as well as the assumptions regarding the vectors involved. There is an emphasis on the need for clear definitions and logical reasoning in the arguments presented.
bobey
let u be a nonzero vector in space and let v and w be any two vectors in space. if u.v = u.w and u x v = u x w, can you conclude that v=w? give reason for your answer.
v is not necessary equal to w
since u is nonzero vector thus the cross product of the vector u with v and w will produce another vector and it is consider the same theirs magnitude and directions are same and their dot product will produce a scalar which has no indication of direction. thus v and w is not necessary same vector.
is my argument is true... or can anyone improve it and prove it with example... your help is highly appreciated... thanx
I have no clue what that means. You start by saying v is not necessarily the same as w, say a couple of general things about cross product and dot product and conclude that v and w are not necessarily the same. What, in what you said about cross product and dot product, led to that conclusion? When you say " it is consider the same their magnitude and directions are same" what vectors are you talking about having the same magnitude and direction? What does "their" refer to?
I think you would be better off using specific formulas. In particular I would recommend using the fact that [itex]u\cdot v= |u||v|cos(\theta)[/itex] and [itex]|u\times v|= |u||v| sin(\theta)[/itex].
It will help to know that for [itex]\theta[/itex] and [itex]\phi[/itex] both between 0 and 180 degrees, [itex]tan(\theta)= tan(\phi)[/itex] implies [itex]\theta= \phi[/itex].
why you think to use this fact : [itex]u\cdot v= |u||v|cos(\theta)[/itex] and [itex]|u\times v|= |u||v| sin(\theta)[/itex] in your arguments? I CAN'T SEE IT!
this is my new argument ::
yes v = w.
u.v = v.u and u x v = u x w implies that u.(v-w)=0 and u x (v-w) = 0 implies that u perpendicular with (v-w) and u parallel to (v-w) implies that u = 0 or (v-w) = 0
thus v=w since u is not a zero vectorIS MY ARGUMENT CORRECT NOW? or any other ideas...THANX 4 D RESPONSE HallsofIvy... :-p
Yes, that is right.
