Proposition 2.2.9 in Duistermaat and Kolk's multivariable analysis
4 replies · 2K views
Math Amateur
MHB
I am reading "Multidimensional Real Analysis I: Differentiation" by J. J. Duistermaat and J. A. C. Kolk ...
I am focused on Chapter 2: Differentiation ... ...
I need help with the proof of Proposition 2.2.9 ... ...
Duistermaat and Kolk's Proposition 2.2.9 read as follows:
In the above text D&K state that Lemma 1.1.7 (iv) implies Proposition 2.2.9 ...
Can someone please indicate how/why ths is the case ...
Peter
===========================================================================================The above post mentions Lemma 1.1.7 ... so I am providing the text of the same ... as follows:
Differentiability of a function ##g(x)## means: ##g(a+v)-g(a)-((D_a)(g))(v) = \varepsilon_a(v)## with ##\lim_{v \to 0}\dfrac{\varepsilon_a(v)}{||\varepsilon_a(v)||}=0\,.##
Now ##D_a(f_i)## are all linear iff ##D_a(f)## is. With the lemma we get
|f_i(a+v)-f_i(a)-((D_a)(f_i))(v)| \leq \sqrt{n}\cdot ||f(a+v)-f(a)-((D_a)(f))(v)|| = \sqrt{n} \cdot ||\varepsilon_a(v)|| =: || \psi_a(v)||
with ##\psi_a = \sqrt{n}\cdot \varepsilon_a## and ##\lim_{v\to 0}\dfrac{\psi_a(v)}{||\psi_a(v)||} = 0##, i.e. the differentiability of ##f## gives the differentiability of the component functions ##f_i\,.## The other inequality ##||y|| \leq |\sum_{i=1}^n\,y_i|## gives the other estimation ##||f(a+v)-f(a)-((D_a)(f))(v)|| \leq \sum \ldots ## with ##\varepsilon_a(v)= \sum (\varepsilon_i)_a (v_i)\,.##
As an important note here: Proposition 2.2.9 is about the component functions of ##f##, not the partial derivatives, i.e. not about the components of ##x##. The situation with partial derivatives is less strong:
  • Total differentiability implies continuity.
  • Total differentiability implies partial differentiability in all coordinates.
  • Partial differentiability does not imply continuity and thus not total differentiability.
  • Continuous partial differentiability, i.e. functions with continuous partial derivatives are also continuous total differentiable.
Thanks fresh_42 ... for such a clear explanation ...
Just a point of clarification ... ...
You write:
" ... ... Now ##D_a(f_i)## are all linear iff ##D_a(f)## is. ... ... "Can you explain how we know this is true ...
Peter
If we have a linear map ##D_a(f)## then this is in coordinates a matrix. And each row ##D_a(f_i)## defines a linear map ##v \mapsto D_a(f_i) \cdot v^\tau = \langle D_a(f_i),v\rangle\,.## And this goes back in the other direction the same way: If we have ##p## linear maps ##D_a(f_i) \, : \, \mathbb{R}^n \longrightarrow \mathbb{R}^1## then they can always be written as ##D_a(f_i)(v)=v_i\cdot v^\tau = \langle v_i,v \rangle## and the ##v_i## give us the rows for ##D_a(f)##. (Here vectors ##w## are rows and ##w^\tau## columns.)
Thanks fresh_42 ... appreciate the help ...
Reflecting on what you have written ...
Thanks again ...
Peter
