Understanding the Distribution of Negation in Propositional Logic
The discussion centers on the distribution of negation in propositional logic, specifically applying DeMorgan's Laws to the expression ¬(P ∧ ¬S). The initial interpretation of the statement "I will not buy the pants but I will buy the shirt" is identified as incorrect; the correct interpretation is "I won't buy the pants or I will buy the shirt." Participants clarify that the correct logical form is ¬P ∨ S, which translates to "If I buy the pants, I will buy the shirt." The confusion arises from differing interpretations of the negation and its implications in English. The conversation highlights the importance of accurately applying logical rules to avoid misinterpretation.
sunny79
Let P stand for "I'll buy the pants.
Let S stand for "I'll buy the shirt.
What english sentence is represented by the formula
~(P ^ ~S)
~(P ^ ~S)
Given that the negation is distributed across parenthesis, P become ~p and S gets double negation ~~S. Hence my solution was " I will not buy the pants but I will buy the shirt. (or and I will buy the shirt, since but can be used in the place of and).
This is from How to prove things by Velleman 3rd edition, chapter 1, section 1.1. However, at the back the solution said I will not buy the pants without buying the shirt. That left me confused.
Look forward to the input.
You haven't stated the rule correctly. The "and" must be changed to "or".
##\lnot( A \land B ) \iff \lnot A \lor \lnot B##
Hello Stephen! They provided the equation outlined below. My task was to convert it into english.
¬(P ^ ¬S). My shot at the solution was " I won't buy pants but I will buy shirt." The answer in the back stated " I won't buy pants without the shirt".
This problem might be an application of one of DeMorgan's Laws; namely, that ¬(P ^ ¬S) ⇔ ¬P ∨ S. The literal translation to English would be "I won't buy the pants or I will buy the shirt."
This proposition would be true in any of the following situations:
1. I don't buy the pants, and I buy the shirt. (both clauses true)
2. I don't buy the pants, and I don't buy the shirt. (first clause true, second clause false)
3. I buy the pants, and I buy the shirt. (first clause false, second clause true)
It's certainly the case that "I won't buy pants without the shirt," as the book's answer shows, but it seems to me that there are scenarios that this answer omits.
The proposition would be false if both clauses are false.
I buy the pants and I don't buy the shirt.
Likes sunny79
Your solution is equivalent to ##\lnot P \land S##. This is incorrect. As I mentioned before, the correct (intermediate) answer is ##\lnot P \lor S## (using ##\lor## instead of ##\land##).
An English equivalent of "I won't buy the pants without the shirt" is "If I buy the pants, I will buy the shirt". To proceed from the intermediate answer to an if...then phrasing use:
##(\lnot A \lor B) \iff (A \implies B)##
Likes sunny79
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
