Prove B is invertible if AB = I
  • Thread starter Thread starter songoku
40 replies · 7K views
songoku
If AB = I for square matrices A and B, show that B is invertible. (Do not assume A is invertible)
##A.A^{-1}=I##
Definition of inverse: Matrix ##P## is invertible if there is matrix ##Q## such that ##PQ = I## and ##QP = I##
So since ##AB = I## is given, first I need to show ##BA = I## to be able to prove that ##B## is invertible? If yes, how to show ##BA = I##?
I thought the answer to this question is straightforward, because ##AB = I##, it means that ##A## is inverse of ##B##, so ##B## has inverse then ##B## is invertible?
Thanks
songoku said:
Homework Statement:: If AB = I for square matrices A and B, show that B is invertible. (Do not assume A is invertible)
Relevant Equations:: ##A.A^{-1}=I##
Thanks
The answer is straightforward if we have a group, but this isn't on our list of assumptions.
I would determine the kernel of ##B## and reason with the finite dimensions.
If you simply treat matrices as elements of a ring, then it can't be proved - as there are rings with elements that have one-sided inverses.
That means you need to use something specific about matrices (over and above the ring axioms).
Sorry my lesson has not covered all those things. What I have learned so far are linear transformations, subspace, inverse, dimension and rank.
Is it possible to answer the question only based on what I learned?
Thanks
Thanks
You need the rank, or injectivity, and the dimension formula, or an embedding argument.
I think the main point here is that you would like to just do matrix operations to go from BA and end up with I. But you cannot, it turns out there are other objects with addition and multiplication where being an inverse multiplying on the left does not imply being an inverse multiplying on the right. So you have to use something special about matrices being linear transformations. The best you can do with just matrix math is observing things like ##(BA)B=B(AB)=BI=B##.
So ##BA## is a matrix which when you multiply it on the right by ##B##, you still get ##B## (and ##B## isn't arbitrary here, it's your specific matrix). That doesn't feel like a lot, but if you think carefully about what it means for a square matrix to be full rank, you can prove that ##BA## must be the identity map (I suggest a proof by contradiction)
$$AB = I$$
$$ABB^{-1} = IB^{-1}$$
$$A = IB^{-1}$$
$$BA = BIB^{-1}$$
$$BA = BB^{-1}$$
$$BA = I$$
EDIT: Apparently you're not allowed to inverse neither A nor B, so this isn't a solution. You sure you read the question right?
Addez123 said:
$$AB = I$$
$$A = IB^{-1}$$
$$BA = BIB^{-1}$$
$$BA = BB^{-1}$$
$$BA = I$$
You assumed B is invertible! This is not a solution.
Ohh haha, thought I A was the only non-invertable one.
Yeah no, then there's no solutions I can think of.
@Addez123 ... what by the way holds true for your equation ##AA^{-1}=I##, too, in your first post. You must not assume that ##A## is invertibel.
Again: Is ##B## injective? What do you know about linear (injective) transformations?
fresh_42 said:
Oops!
I was slightly confused at the reponse :p
fresh_42 said:
You need the rank
What it means for a square matrix to be full rank is that the columns of that matrix form a linearly independent set but I don't know how to use that fact to proceed.
Proof by contradiction means that I start from assumption that B is not invertible?
fresh_42 said:
or injectivity
I don't know whether B is injective or not.
What I know about linear transformation to be injective (one to one) is that ##B(x)=0## has only trivial solution.
By dimension formula, do you mean dim (col B) + dim (nul B) = n (assume B has n columns)?
The only thing I am sure about this question is I am 100% sure I posted the question correctly as I got it and I am also sure I don't know how to solve it
The vectors in a matrix probably won't help here very much. Of course, you can use them, but I think it is easier without them.
Yes. An injective function satisfies ##f(x)=f(y) \Longrightarrow x=y## and if ##f## is linear as in our case, this means ##f(x-y)=0 \Longrightarrow x-y=0## or equivalent ##f(v)=0 \Longrightarrow v=0.##
So assume ##B(v)=0.## What does that tell you, given that ##AB=I\;?##
Yes, although it is better known as rank-nullity theorem:
##\operatorname{rank} B + \operatorname{null} B = \dim\operatorname{im} B + \dim\operatorname{ker}B= dim (col B) + dim (nul B) = n= \dim V= \dim \operatorname{domain} B.##
Since you have (hopefully) shown that ##\dim\operatorname{ker}B=0## you will get the rank of ##B## from that formula.
The question is right.
Assume ##B## is ##m\times m## matrix and ##B(v)=0##
$$AB=I$$
$$AB(v)=I(v)$$
$$A(0)=v$$
$$v=0$$
I have not learned about "ker" but I searched a bit about it.
Dim (nul B) = 0, then rank B = ##m \rightarrow## B has full rank, so B has ##m## pivot columns and B is row equivalent to ##I##. This means that B is invertible
Is this correct? Thanks
Are we allowed to use properties of determinants; specifically for Det(AB)?.
Or of Rank-Nullity and Rank of a product?
My lesson has not covered those things. For rank, the notes from the teacher only state "rank theorem", not Rank - Nullity and I only learn about rank of a matrix so far, not yet about rank of product of matrix.
Thanks
Thanks
It may be reasonably feasible to provide a broad. i. e., not the sharpest possible, bound for the rank of the product. If not, maybe we can drop this option.
$$AB=I$$
$$AB(v)=I(v)$$
$$A(0)=v$$
$$v=0$$
This is a good start. You've shown that ##B## is one-to-one - although critically you haven't actually said that. Is that what you set out to show? That ##B## is one-to-one.
In any case, if you can show that ##B## is also onto, then you have shown that ##B## is invertible.
There's no need to talk about full rank, pivot columns or row equivalence. You should have been aiming to show that ##B## is onto (or surjective, if that's the terminology you are familiar with).
Yes
I think I can show ##B## is onto but using pivot point. Since ##B## has pivot point on each row, ##B## is onto.
How to show it without using pivot?
Thanks
Thanks
What is the rank theorem?
If B has n columns, rank B + dim nul B = n
This is also known as the rank nullity theorem. So what is dim nul B, given what you have figured out so far?
dim nul B = 0
songoku said:
dim nul B = 0
This is correct, and if will be more educational if you think about what other conclusions you can now make.
I have tried to answer the question in post #18
Or do you refer to post #24?
Thanks
